Underbody rust
I got my 99 Silverado washed the other day, with the underbody wash.  I got under it to make sure all the salt was gone and noticed that the steel frame had some rust on it.  I do remember while off roading one time I went over a dirt mound and hit the bottom.  How should I go about taking care of this?  Sanding then putting some rust olium on it?  Help please
-KMT15
I'd wire brush it and clean it up as best as possible.  Then I'd spray it with either a can of the rubberized undercoating or several coats of Rust-Olium or the like.
The frame is coated with a "wax" from the factory.  I don't think you can find anything that will replace it perfectly.
Yea Shanners you got it...you can buy a rubberized undercoating at your GM dealer in a spray can. It works great...it is a clear color though so you will want to spray it with some black underbody paint like Rust o lium. Your GM dealer has this to in a relabeled GM flat black paint. :jester:
