So, still shopping for good deal on wheels, but was wanting to ask, only because i cant find anything i like or that meets all the specs for the lift.. Zone 6.5" I havent measured yet, but will or can this weekend..
Couldnt i add a small spacer, to be determined after measuring OEM wheels, to my 20" Polished Aluminum rims so that i only need to upgrade the tires or even run them for a while before rushing into everything..
Im ready to get the lift, just need to schedule. Looking online at tirerack, discounttire, 4wheelparts and other sites.. there are plenty of rims out there, but the ones im finding at right size, right bolt pattern, but wrong backspacing.. Zone states 5.75" for 20's and 5" for 17's everything i find shows back spacing around 4 to 4.75
If i order the rims online, i want to make sure i get the right thing..
These are the ones i have now.. im ok with these if they can be used.. specs are 20x9 i think the paperwork shows..
i havent removed one to find the backspacing and offset yet.. but if a thin spacer would work, id be all over this and in line to get the lift ASAP.
Any one know the true specs on these rims?
Size:
BackSpace:
Offset:
20x9 offset is probably +27 or +30. It says on the inside lip. If you have stamped steel UCAs they most likely won’t work with zone. On 35s you can run a x9 wheel with a 0 offset with no issues
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
Size:
BackSpace:
Offset:
Okay, that was a lot but I will do my best. I put a Zone 6.5 on my 2014 sierra about a month ago so I know what you're feeling. I am running a 17 inch XD wheel underneath with a 0mm offset. From using converters etc..I guess a 5 backspace is the same as 0mm offset. It all kinda confuses me honestly and I was nervous like you are to order online but luckily it all worked out. I don't know anything about the spacers really so I can't help you there. Good luck!
Bought my Silverado a week ago and just had it lifted...Absolutely love it.
7-9" McGaughy Lift
22x12 Fuel Mavericks
35x12.50r Toyo RTs
7-9" McGaughy Lift
35x12.50r Toyo RTs
22382155_10214172763303315_2554083725633847176_o.thumb.jpg.fcb104e653aef7d16972ba6d9a0ab4a7.jpg
Fender measurements?
Sent from my SM-G903W using Tapatalk
I've got a 2014 2WD Sierra.
Anyone know if the Zone 6.5" will allow me to run the stock 20" wheels with a 35x12.50? I really like the stock wheels and don't want to cough up the dough for new wheels.
Anyone running a 6.5 zone on their stock 20's?
It depends on your control arms. Most people (including myself) are unable to run stockers with stamped steel control arms due to the design
4.5" Zone
22x10 AF Grips
6" lift guys with 35's, what is your overall height to the top of the onstar antenna (not really worried about the FM radio height)?  And is anyone running the factory 22" wheels? I like the OEM's and don't want to have to shell out the $$ for a new set of wheels.  I have an 82 1/2" garage door opening (under the weather stripping) that is worrying me about this setup.  I'm still in the looking stage as to what I want to put on, because it has to fit in the garage.  Thanks for the help.
I have a zone 6.5 with add a leaf running 325/60r20 and im around 81-82 inches. Tried to be as accurate as i could be without a stool to stand on.
So I emailed Zone about the possibility of running stock 20"s with their 6.5" lift and they responded stock 20s will work fine with a 1/4" wheel spacer.
I'm not too familiar with wheel spacers but 1/4" doesn't seem like it could hurt too much.
Its that or run the rough country 7" where the stockers should fit fine without spacers. I've just read more positive things regarding the Zone lifts.
Zone is much better. If you don’t have stamped steel control arms you won’t need any spacer. Also make sure the spacer is lug/hub centric
4.5" Zone
22x10 AF Grips
On ‎9‎/‎7‎/‎2017 at 8:50 AM, Irby1757 said:
I know there has been a lot of discussion about what lift size to buy. I have a newborn, and a wife that is just 5 foot tall. So when we decided it was time to lift we both thought that going with the 4.5" lift was the way to go. After many hours of research and driving around to dealerships to crawl in and out of lifted trucks, we went with the Zone 6.5" (w/ Fox 2.0 shocks). To me, it is perfect. Even without steps (waiting to by Amp steps) it is manageable to get in and out, and putting my son in his a seat is actually in a better location than when just leveled. My truck could never fit in the garage due to length anyways, so that was never a concern.
Tires are 35x12.50 Toyo Open Country MT
I know that seeing all the trucks on here, and reading opinions helped me a ton. Hopefully this will help someone out at some point as well.
I love the way your truck came out. I'm pretty much sold on Zone but I can't decide between 4.5" and 6". My fiancée is also short and we will be having kids in the (far) future. What was your MGP drop? I also have to think about my 70 mile round trip to work every day.  Also, what shop did you use? I'm in the Dallas area too
I appreciate it! I sent you a PM with more information.
Could i get away with running bilsteins on the loswest setting, which is around 0.75", on my zone 6.5" lift? Couldnt see it being an issue as its not even an inch. Im upgrading to bilsteins on all 4 corners so i figure i may as well squeeze a bit of lift out of them if i can.
Could you? Yes.
Do I think it’s a good idea? Definitely not.
4.5" Zone
22x10 AF Grips
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   4 Members, 1 Anonymous, 5,052 Guests (See full list)
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
