ok, cool, yea i was noticing that..i know wife is ok with getting the 6" lift on the truck so that we dont loose it if it floods in our area again, but knowing that there is another lift higher out there may be worth considering ;)
thanks for the insight on the Z71 and what would be changed out
Odd request. Can anyone with a 6 inch procomp lift with the upper strut spacer and add a leaf get some fender measurements? Thanks in advance
Sent from my SM-G903W using Tapatalk
What is the safest wheel size and offset to consider with a 6" lift?
The truck comes with the 20" clad rims.. calling around for having the lift done vs doing it myself, but curious about offset to consider.
Id like to run 35's , but shelling out $5k for a package deal(lift, rims and tires), seems pretty high when i can buy the rims and tires for around $1600
So any safe sizes i can consider to run 35's if i did the lift install myself?
”Safe” is subjective, but any width from 8-10 is “safe,” x12 is where you start to push it as far as stress on front end components. However there’s other factors to include as well such as adding wheel spacers (to the front) or adding leveling spacers as well. All these things combined will begin to make it unsafe.
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
4.5" Zone
22x10 AF Grips
So when i meant safest, i meant that i could order online or locally or buy off someone that i woudlnt be wasting my time.. I dont want to cause issues to the truck being new.. and not looking for widest tire, but def want to get in the 35's
Stock rims that are on the truck are 20x9 but the offset is not there to keep them after the lift.. So if i chose to stick with a 20" rim looks like i would need to get a rim with a 5.75" offset/backspace?
So safest would mean if i found someone that had some rims 20x9 and 5.5" would that work? Just looking for safe ranges of sizes
Very sweet did you do the install yourself or have it done?
you could run x9 with a 0 offset easily on 35s
4.5" Zone
22x10 AF Grips
4.5" Zone
22x10 AF Grips
Wouldnt that mean i could use my stock rims then? because my rims are 20x9 already
i had it done by a local shop close to me.
2015 1500 LT Silverado Midnight Edition
You need to look at the backspacing of the rim, and what brand of lift you are using. The zone lift says that you need wheels with 5 3/4" backspacing for example. If you don't want to trim anything, I would make sure that you follow along with what the manufacturer states. Not that it may not work, but why not wait until you can do it right. Trucks are too expensive to hurry into modifications on. Find someone to buy your stock rims, people usually pay good for them.
Edited by Irby1757
not necessarily, the large positive offset of the stockers could make it so that you can’t reuse them. It depends on the lift and control arms you have
4.5" Zone
22x10 AF Grips
The reason im asking, is because i was quoted $2520 for wheels and tires, plus the cost of the lift as well..
SO i rather find more reasonable wheels and tires before i have the lift done..
Not looking to run stock unless i can, my last truck i had lifted.. it was the smallest lift you could get on a ford just after a leveling kit, so whatever size taht was, i was able to run my stock rims and then get larger tires..
So thats why im asking. I would be ok with the stock rims as long as they worked, but if they dont, thats fine but not looking to spend $2500 on wheels and tires..
If i can find some less expensive or even someone selling a set that has the right offset /backspace then i can get those before having the truck lifted.. and be set..
$2500 for wheels/tires is CHEAP lol. However I understand what you’re saying and stockers look good too.
4.5" Zone
22x10 AF Grips
Did it require any cutting for the lift kit itself? Aka could your truck easily be returned to stock?
i was told that my truck will not be going back to stock anytime soon. From what my research told me, this kit was the least cutting between BDS and Zone which are the same company.
    whenindoubtuseahammer
  • Who's Online   0 Members, 0 Anonymous, 289 Guests (See full list)
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
