I'm guessing by looking at the kits instructions it doesn't widen the track at all, like a rough country "bracket" kit vs a knuckle lift which widens front track
it widens the front 1.5" per side
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
There is one point to make and I assume for at least the 14-15 sierras that if you get a Zone kit specifically the 6.5" kit even though I'm sure it applies for the 4.5 as well, and have a crew cab, get the add a leaf. This will make your lift level. I originally was told by zone themselves that the add a leaf wasn't needed unless you wanted more payload. This is not the case and your rear will be about 1" give or take low and will have your hood nose high. I didn't know the guy I originally talked with but their kit states 6.5 in front and 5" block in back. That is supposed to be level but is not. It does actually say that on the website or so I'm told haven't had a chance to verify after I spoke with zone today. What a bummer. Something else to change
The 4.5" kit sets level/slightly raked with the 4" block included
4.5" Zone
22x10 AF Grips
4.5" Zone
22x10 AF Grips
slightly raked meaning the rear is a in or so lower
rake means the back is higher
4.5" Zone
22x10 AF Grips
4.5" Zone
22x10 AF Grips
I figured but sometimes people use diff words so I figured I'd ask to make sure.
My zone 6.5 is leveled without the leafs in the rear and stock zone block.
I have the zone 6.5 on my 16 sierra crew cab and im actuallu getting the add a leaf installed next week cause my rear end is about an inch lower with the 5 inch block. Looks wonky especially from a distance
Sent from my SM-G903W using Tapatalk
Does anyone have the BDS 6" installed? If so can you send pics, that is the one I am looking at right now.
Well after reading 200+ pages of this thread. I didn't notice one thing, anybody towing heavy with 35s? I planned on a 6.5" on 35s but I tow 8klb every weekend in the summer. I'm being told 35s with a 5.3/3.42 gears is extremely bad. A local truck shop advised me to go smaller lift and keep my 33s.. any input?
6.5 inch zone. I have the 6.2 8 speed. Havent towed 8000 but tow well over 5000 it handles and tows great imo. Add a leaf going in this week to prevent sag. No experience with 5.3 and lift.e21a86c6155dda7c8b90436ff3906efa.jpg
He wasn't really saying the lift was the issue, more along the 35" tires being larger and changing the gear ratio essentially. Said I should regear to 373's at least if running 35s and towing my 8k boat..
I have not towed anything, but I have a 5.3 with 3.42 gears on 35's and I have not noticed any issue with acceleration/power. I also do not believe that dealerships change gears when they lift trucks. Hopefully someone that tows often can give you some good input.
They definetly don't regear at dealer, they'd cost to much. The point this guy made was check tow rating of a 5.3 with 3.08's cause that's roughly what a 5.3 on 35s ends up being? Has to be some type of calculator online to check this.
    • Paid $2.72 for E85 today.
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
    • And use RA's 5% discount code if you buy from them.  google for the code, one is always available.
