i will definitely look that up and do some research!
2015 1500 LT Silverado Midnight Edition
Sent from my iPhone using Tapatalki did forget to mention they said leveling kits were fine....
One thing to note on that CST lift is that it requires cutting of the crossmember, differential and drops the UCA's, so there is a lot more modification Involved versus a typical spindle lift like BDS. That might run you into some warranty problems, but I'm sure you could end up fighting them. I'm looking at that exact same lift - IMO, you made the right decision in terms of quality since You're not replacing spindles it will keep all angles exactly like stock. The diff drop and control arm drops measure out to exactly 4.5" also, so things stay flat. My truck is just out of warranty, so im pulling the trigger on that lift - If you decide you don't want it, let me know I'll buy it off you!
i might take you up on that offer.... I'm waiting to talk to someone higher up at the dealership for a solid answer. I'm now looking at a leveling kit for now that will work with the fox 2.5 coilovers I have and fox 2.0 rear shocks
Keep me posted, man! Did you have custom shocks made for the lift? If not, you don't need a leveling kit. You will be able to pump up those shocks 2 inches for a level look. Shoot over a PM and I can talk you through it. You might want to call AutoPlex out of Colorado also. They are putting on 6in Zone lifts for new trucks out here for all the dealerships. The dealer sells it as a new truck with all warranty included, so they might be able to give you some more information around that.
pm sent!!
My biggest was the guarantee to cover your truck limited lifetime for the kit but also if the kit causes an issue that the dealer won't cover zone will. Also background zone is the sister company to bds. At close to half the price. This 6-800 diff is the no hassle full lifetime warranty that bds gives. So if you beat the shit out of your truck and break something intentionally bds will replace it no questions asked as zone will not. If there is a manufacturer fail point for the zone kit it will replace it.
Haven't heard rough country have any kind of warranty or guarantee like that.
Pro comp has a similar guarantee for the factory warranty but I do t think any kind of lifetime warranty on parts.
I'm seeing a lot of people choosing zone lifts over rough country. Any reason behind that?
warrenty, price, options and the affiliation with BDS and Fox
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
I'm tossing between an RC 6" and zone 6.5". Really don't like the idea of welding brackets with the zone kit. Even the 4.5" kit requires welding with zone? What's up with that? Would an aftermarket control arm solve that?
No, and I'm pretty sure BDS needs welding too. It has to do with the Lower rear crossmember.
4.5" Zone
22x10 AF Grips
Edited by wildchevys
I haven't seen a rough country in a while but was a brand that never even thought about. There is a reason certain lifts are certified and they stand behind their products. Not bagging on RC but not a way I'm going. I pick my truck up in a couple hours. I'll post pics when I pick her up. I'm sure my tires are gonna be a bit small as I refused to get rid of tires with 65-70 tread to go to 35" at the moment. Kicking 33"s right now.
I just put the Zone 6.5 on my Sierra probably about a month ago. My dad and I did it ourselves and it was pretty simple. We were definitely nervous about the cutting and welding (we have a little suitcase welder but nothing serious) but it was all actually super easy. What you weld isn't structural and won't affect the structural integrity of the suspension at all, it's more like a cover. I think it says too in the directions if you can't weld it you can finish the install without it and get it welded in later on. Hope that helps.
The weld in plate is more for added rigidity than anything else, I think.
I'm guessing by looking at the kits instructions it doesn't widen the track at all, like a rough country "bracket" kit vs a knuckle lift which widens front track
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 505 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
