Jegs has these on sale just got the email - If I can get a plug type for the plug in under the bed I am considering ordering me these instead and putting at the cab end of the bed http://www.jegs.com/p/Hella/Hella-Optilux-LED-Worklamps/2889960/10002/-1
here is a site with the specs on them http://www.rallylights.com/all/optilux-model-4sq-led-work-lamp.html a little over 5 inches high wonder if they would be too big?
To me those would be too big and too bright for a bed light
My Sierra has em I'm thinking of adding a couple more. I'd really like a switch for them at the tail gate.
I dont plan on leaving the tailgate down for extended periods of time, so the tailgate operated switch would work fine. If the tailgate is going to be left down for several hours or days at a time, then I would tap into the existing cargo lamp circuit.
do you have the plug from the end of the wiring that goes into the module? If so what would you have to have for it?
yeah that is what I figured out after I went out and measured as well but the brightness would of been awesome in my case trying to find small parts in my boxes in the bed
Cool! I just ordered one of those. Do you like it?
Sure do. The cargo does not slide around, and my knees do not hurt when I crawl in the bed of the truck. I also like the finished appearance of it. It fit really well, and does everything I ask of it.
I will look, but I think I tossed them upon completing the install. Will let you know if I find one.
thanks I would like to put some LED pods I already have in my bed if you can find them
  • 4 weeks later...
I have the bed LED's already but I would like to add a second set up front? whats the easiest way to do it? hardwire since there isnt a second plug in the juction box? any help would be appreciated!! thanks
I spliced two GM sets together. I soldered the red and black wires together, and used heat shrink wrap to seal up the splices. Worked well..
i didnt even realize what a good option it was at the time when i orderd, but i didnt get the lights installed
I ended up buying the the plasmaglow led lights off amazon
placed them under bed rails
ran the wiring through the cab vents ( easy ) and up into the third brake light i tapped into the left and right wires of the white bulbs and spliced the ground together and tapped into the ground wire of the third brake light.
now when i press the button for the cargo light on the dash the lights come on!
Before all this I asked my dealer to, and they said "well its still a new truck we really dont know yet ......"
so it only took me like an hour and it was alot cheaper
pic below
OH!! and as for the wiring already being there for the lights ... did not see a single thing : (
unless its somewhere inside the truck behind the back panels
can you let me know exactly which wires you tapped in to. Thanks
Sent from my SM-N900T using Tapatalk
Can I still easily install these with a spray in bed liner?
On a '14, there are prepunched holes under the bed rail that small clips snap into, and the mounting screws screw into them. As long as the bed liner material hasn't filled them in, you will be OK.
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 1 Anonymous, 746 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
