So....used E85 yet?
You'll notice the longer crank times once it's flowing through the system.
Sent from my SM-G930V using Tapatalk
Noticed that this morning when i started the truck.
Yep. Same here.
  • Replies 171
Hey guys. I was going thru my vin and I have a link that tells where your trucks made blah blah. But on the vin I have a C in the 8th place which states a 5.3 e85 max. I don't have a yellow cap so what does this mean. I can or can't run e85
Sent from my Nexus 6P using Tapatalk
That's what I thought. Why would the vin denote I could? Was hoping for just a second it would be e85
Tapatalk
I have a c also. I have also run e85 for 500 miles with no side effects. I do not have the yellow cap there is a difference in the power output,and less mpg
Yeah I looked up my vin and it said I had a v8... 2 cylinders must be hiding [emoji23][emoji23] Go off RPO codes on the build sheet.
saw that many people had done the add on from an ebay visor homelink so i decided to make a video to share on how i did mine. hope this will help someone out on their project. it was not very hard to do and only cost about $9 it works very well and you need almost no tools. you dont even have to cut any wires no no void of warranty. DIY HomeLync Garage Door Opener 2015 GM Truck
Thanks for the inspiration of all the people in this forum
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 636 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
