So....used E85 yet?
Yea it was a 1.64 last night when I filled up when we were tuning it. I got 23 gallons for $38, I was pretty happy with that since double coupon at SA is gone now :( .
Best part is if I got extra e85 leftover from racing my car I can now dump it into the truck, and don't have to worry about running out of gas in the truck cuz I usually carry 10 gallons with me to the track, LOL.
  • Replies 171
I am not sure if you have a Holiday near by, but I have found they typically have the highest Alcohol % in their e85. They accept all coupons now too.
I filled up yesterday at my local Holiday which was $1.459 per gallon. Then I used a .10 coupon and .20 from cub rewards per gallon. So, $1.159 :).
Nice dude! Yea we have them all around Cottage Grove. I use BP for the Trans Am regardless of price as it has tested the highest for me using an e85 tester. I like to stay consistent with the Trans Am with fuel so my AFRs aren't all over the place when i get to the track.
I tested SA last fall at like 65% and I had it my Trans Am and it was soo rich from all the gas content it was crazy!
For the truck it will get the cheapest e85 possible since it can compensate for it, it won't matter what the alcohol percentage is nearly as much.
What did BP test for you? I don't have any close by, but there is one by my work kinda.
Holiday over here is 79%.
Its usually 80% or higher, I haven't tested since early summer.
Cool, I'll have to test a tank to see what it reads out.
Mine v6 is getting around 12, but I have been foot happy. The truck drives completely different. Like it was made to have e85 run though it. Idles smoother and transmission shifts are not happening as much. Not to mention the "go go" feeling when you get on it!
Hi all, I'm a little late to the convo. I just read this whole thread and I have a question when switching from gas to e85. I read that the car will adjust the timing based on the fuel it detects. Does any type of notification come up or light turn on that tells you it detected the e85 (or the change in fuel type for that matter)?
I wanted to wait until I got the first 1000 miles in before I try and make the switch. Of course I'll let it run down as far as I can before adding the new fuel. Just wanted to know if the car tells you it detected the change. Thanks in advance.
Nope, no lights or notifications.
Sent from my SM-G930V using Tapatalk
Today is the last day SA will double coupons, they are under new ownership again in MN.
Found that out today when I went into one for the first time in a couple of months. No more incentive to go there now!
It doesn't tell you with a light, but you'll know. I remember exactly when it kicked it. Good times [emoji23]. It does take a few miles, but I was in town and was going through stoplights and the next time I stepped on the gas it was a different truck. I can easily spin wheels now [emoji16]
Since regular has moved up some, E85 is getting into the price spread where it is becoming viable again in my area. Right now regular E10 at around 2.25 in my area and E85 is at $1.59. Just about at the break even point on cost per mile based on the different mpg's for the fuels. Looks like E85 will be going back in the tank soon.
Ha! You said it. It makes driving the truck even more fun and it certainly is a noticeable increase in performance.
I average about 22% less mpg with E85 but it's about 28% cheaper than regular gas, so as long as I can make out and have better performance in the process, it's a no brainer.
I've probably been running E85 for the last 10 tankfuls and will run regular gas again if I have to, but I won't like it.
You'll notice the longer crank times once it's flowing through the system.
Noticed that this morning when i started the truck.
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
    • I have a trailer lights checker I plugged into the 7 way connector in the bed of my truck that has the 5th wheel/gooseneck hitch. It gave the camera side view with the turn signal on just like having a trailer connected but it disabled the rear bumper sensors. I would rather have the rear sensors working.
    • You are winning more than battles. You're winning the war!  Nice.
    • Blazer is all put back together. Another hard-won battle. The 4.3 is not easy to work on in such an archaic and narrow chassis originally designed for an inline 4.   My baffle issue is solved. I returned to the OG junkyard but was ready for a fight. The Blazer I had picked from was stacked on another vehicle so I had no idea how the heck I was going to get myself to working height to pull the front end apart. I had seen an S10 pickup on the ground so I was hoping the part would be the same, AND, I couldn't remember if the S10 still had a front end or not. But I didn't need to worry because it turned out to be my lucky day. The yard had just taken in a '98 Blazer, sitting right up front, on the ground, with room to work around it, and the front end hadn't been hit. The baffle and all the clips were factory perfect. I also scored another good handful of odds/ends and the whole shebang only cost me $20.   Got everything back together and it fired right off, sounds good, runs good. I've got a little coolant drip from a lower water pump bolt (D'OH!!). I did the right thing and snugged it down a little bit, and of course that didn't fix it. Yet again, I will have to soak everything in coolant to drain it down to the water pump, remove the bolt, and attempt to re-seal it. Nothing is easy on this truck. Nothing. But now all the radiator plastics are correct, snug, and fully functional. No more rubbing on the cooling fan. It runs, drives (took it for a 30 mile drive last night), no Check Engine lights, EGR is working, no vacuum leaks. We're getting closer...   The replacement wiper motor arrived yesterday. The tailgate was already disassembled and waiting, so I threw that in. It works! Sort of. Two new issues on the list. While the motor is strong enough and the gears aren't stripped, the wiper is hanging up on the bottom of the rear glass. This is the old style where the lower half folds down like a truck tailgate, and the glass swings up, and they meet in the middle when closed. The glass isn't sitting flush with the tailgate, now that I look at it. No rubber bumpers that I can see for adjusting, so I'll have to look at the hinge adjustment to see if I can correct it. Also, the washer/squirter just dumps fluid underneath the truck. The lines actually run inside on the floor so I'm guessing the tailgate is soaked at the rear trim and the line is disconnected. There's also a drain there....probably for this reason.   The leaky water pump bolt was really disappointing. JUST STOP LEAKING...OMG!!   Replacing the window motor and a rear door speaker are still to do, and then everything will work. I want this to feel like a "good" vehicle worthy of dropping $600 for new tires before I do. That means no leaking first. I hurt, and I'm kind of cranky, so I'll probably take a day of rest and do the water pump again tomorrow.
