kodiakz - can you tell me part numbers for what i need? Is there anyone who is providing installation services for this video input device?
were you guys interested in altering the calibrations or actually installing you own software?
Use our own software.
Need to learn more about the bootloader. I found a dev screen by pressing power+home+menu.
lot of work seems like to run your own software when you could just use one of the aftermarket android or wince devices and run it from the touchscreen
  • 4 months later...
Hey Kodiac, any update on sharing a usb update package? I too am interested in breaking it down, or at the very least seeing the file structure to deduce what's needed for the update via USB
So did everyone just give up on development of this thing?
When I heard this system was open source I got visions of custom themes, and taking advantage of the hardware in new and exciting ways... Like gauges and stuff.
Let alone enabling Android Auto or free use of backup cam for less than the $1,000 other companies charge...
Hello! I have a 2015 Yukon and would really like to upgrade the infotainment system. I am very interested in finding a more cost effective and better solution than current mod vendors' solutions. There has to be a better option(s). The current "upgrade" options are barely an upgrade, especially for $1000+. We seem to have all the needed resources and data to truly upgrade the Intellilink/MyLink/CUE system. How nice would it be to use google maps in your GM vehicle?!
That said, I'm won't be much help on the coding side but I'd be happy to provide any info from my truck and try stuff out.
Thanks!
Andres
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
