None whatsoever.
well that's good news. Because my wheels R +18 TIS Monster with 2" RC Leveling and am running 305 50 20 and want to run your size but was told by others it would rub. [emoji106]
Sent from my iPhone 6
using Tapatalk
using Tapatalk
Yeah, I've cut the wheels hard side to side while backing and going forward and still haven't found any rubbing. I haven't been off road or anything though. But the extent of my off-roading is the beach during the summer.
cool. That will work. I don't off road at all. Just pull a 4,000lb trailer. That's about it
using Tapatalk
using Tapatalk
My 2014 Sierra All Terrain. Crew cab standard box, 6.2L. Bought it 3 weeks ago. Loving it so far.
  • Like 5
MY '14 Sierra 5.3, factory chrome CK919 22" wheels, Bridgestone tires, Carriage Works grille, Gibson dual rear exit exhaust, LED fogs, 6000K Xenon bulbs, leveled rear.
Edited by mafd2
boom
Love the wheels are those the same as the all terrains?
Those are the replicas of the All Terrains
yes sir. they actually came with the truck when i bought it
do you know where you can get those?
from my understanding they are a stock GMC rim and can get at dealership. also seen them online. ive noticed some trucks having them. they are 20's but kinda wished i had the 18's for better gas mileage.
You buy a 4X4 full size truck and are concerned about maybe pennies in mileage between an 18" and 20" wheel tire combo? Lol...
    Randy Ginoza
    Randy Ginoza
  • Who's Online   3 Members, 0 Anonymous, 2,122 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
