Its the factory grille. I just removed it and took it apart and plasti dipped it all.
Looks awesome!
Finally quit raining so I took out the kayak and went fishing for a bit today.
What bed rack is that? I'm looking into one for mine.
Here's my 2015 Sierra All-Terrain and list of mods:
2.5" RC Level + RC Rear Blocks
295/55r20 Toyo AT2 Xtreme Tires
BulletProof Black Offset Flaps
Undercover Flex Tonneau
3m'd Front
35% Front Tint
MAXpider 3D Floor Liners
Muffler Delete
Eventually like to get rid of the chrome on the sides and debadge. I'll probably pull off the running boards as well.
I know this is a "Post YOUR Truck" thread, but one of the perks of working for the dealer on the side is that I get to drive some pretty cool trucks occasionally.
Here's a couple from yesterday:
15' Denali 6.2, 6" Lift, 35's on 20's.
14' All Terrain, 10" Lift on 37's on 22's.
3m'd Front
35% Front Tint
Muffler Delete
How do you like your AT with the rc rear blocks? I've been going back and forth on whether to leave the stocks in or replace with the kit.
That picture is literally 5mins after I had the rear blocks put in. Initially I just went with the 2.5" up front and left the rear stock. It was almost dead level on a measuring tape, 39.75" up front and 40" out back. Unless you were looking at it from the rear it looked "nose high" to me and I was worried it would have too much sag in the back when I hooked up to my travel trailer.
Factory blocks are 1.25" and the RC are 1.75" tapered to 2".
Now I'm sitting about 39.75/40.5 which will work better for towing and from the side it doesn't hardly look any different but got rid of the "Cali lean".
Stock Blocks:
RC Blocks:
Edited by hutch08
Stock Blocks:
RC Blocks:
Alright cool thanks for the info. I'm getting the same kit installed tomorrow and I've seen a lot of back and forth between stick blocks and rc blocks. Thanks again! [emoji106]
Nice looking truck, I've always liked a black GMC/chevy with dark tint like that. Too bad TX doesn't allow it for us. We can go dark as we want in back but front windows have to be like 30% or less I think.
25% in Texas for front windows and it can be any color except red, blue or amber.
Here it is. Last post messed me up.
I think it looks good man. If you are iffy on them I would try and paint them all black. I think they would look even better.
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 1,633 Guests (See full list)
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
