Here's my 14 All Terrain 6.2 SLT
Truck looks great, and quite familiar haha... Rough Country 2.5" up front + blocks in the rear?
Any idea what your fender measurements are? I've got a similar set-up but left the factory blocks... trying to decide on leaving it as is or swapping in the RC blocks.
I currently have about 0.25" of rake in the rear:
My 2014 sierra with a 3.5 inch rough country suspension lift, 295/70r17 toyo rough country m/t tires and 17 inch fuel maverick wheels.attachicon.gifimage.jpg
How do you like the RC 3.5?
I'm debating on switching to it from my 2.5.
Here's how my 2014 All Terrain is as of now.
I like your truck! What is your set up?
Definitely no complaints so far. I really like it. It gives a really good balance between stock height and crazy lifted
On my 2014 Crew Cab 4X4 I went with Cooper Discover ATP's which are a P size tire and a bit lighter weight that LT tires. I believe they are 52 lbs and rated 6 ply. I really like the ride so far, not as harsh as my Goodyear Eagles LS2's I had. Also taller and fill up the wheel wells better.
2014 Crew with full install of RC 2 1/2 level lift and Cooper Discoverers 275 60 R20's on stock OEM 20 x 8.5".
They state 33" in diameter but after mounting they dropped to 32.5" which is better than the Goodyear Eagles LS2's I had at 30 5/8".
Mild look but happy since I didn't need such aggressive tires such as the Nitto Terra Grapplers.
Finally quit raining so I took out the kayak and went fishing for a bit today.
Perfect imo, if I were to change anything at all, it would be the wheels. They look great as it is, just might slap some black ones on there. That's how black and white should definitely look!
Kobelco's huh?
ya they make nice excavators, and a good truck pic background haha
you are correct, 2.5" RC kit with the block in the back. Not too sure why but all four corners have different measurements
LF 38.25" LR 39.5"
RF just under 39" RR 39 1/8"
I think I took some measurements the day I got the kit installed written down somewhere. Going to have a look. I have some weight in the bed for winter time that probably drops the rear a little as well. Also running 275/60/20 tires
Got the truck washed today, beautiful weather out in Dallas today so decided to snap some pictures. Showing off the new exhaust and new GM black sidesteps.
LF 38.25" LR 39.5"
Yeah unless you're on perfectly level ground the little bit of flex will definitely throw your measurements off. Typically the passenger side will be a little higher, probably due to the fuel tank weighing down the driver side.
Sounds like you've also got about 0.25" of rake, the added weight must be bringing it down a bit.
I measured the stock blocks and they're exactly 1.25" with no taper;
The RC blocks are tapered, 1.75" at the front to 2" at the rear so I'm assuming if I install them I'll end up with an inch of rake.
Edited by hutch08
looks good man. Sometimes i regret not buying a GMC.
    Enduro73
    Enduro73
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
