Seen plenty of guys run that tire size with no rubbing. Check the leveling thread. I've seen sizes up to 305/55r20 run just fine on stock wheels.
I appreciate it! Yeah I have read through alot of that thread but most of the people I see running them are 2.5" lift. Also, I love those HID's. I have the emerald green and think those green ones would look pretty good.
Looks good. You use glossifier or just matte black?
just matte black. It has held up well. Easy to do.
33 nitto trail grapplers. 2015 sierra z71
Edited by Contender
Prius owners told me to go green, hope this is what they meant. :P
[emoji23][emoji23] I usually rev the engine when they tell me to go green
Decided I'd go chrome again. Was trying to do a black and white theme but I can't get rid of some of the chrome. So I'll embrace it. Chrome haters gonna hate
6D95FB58-75B5-419C-AA37-17530D16E7C3_zps
  • Like 3
Can you post more pics? I assume this is 2.5" level factory 22s and 285/45 tires?
It's the factory ride height. But they are factory Tahoe 22s I'll get more pics tomorrow
Truck looks great. I have the same set up SLE with the same rims. What lift do you have on it and what size tires (2XX/XX/XX)?
I like them. I had the Toyo AT 2s before and these make the truck look a lot better IMO. The ride is still good and the noise isn't bad.
They look really good! How much larger do you think you could have gone?
Edited by grapedrinkesha
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,185 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
