I'm running the 7" RCX.
Thanks. Do you know if it's possible to run 35x12.50R18?
I think Stevencox has a 35x12.5x18 on his 7" RCX
Thanks Mike, I kept seeing on their website, 35x12.50R20. I didn't want to have to buy new wheels. I already have 18x9. I sent RCX an email we'll see what they say and I'll let y'all know.
Yeah I'm running 18x10 on 35x12.50
I will call it Vanilla Ice :chevrolet:
10467759_1502483493320236_1910783606_n.j
2014 Silverado LT Custom Sport 4x4
LTZ chrome skid plate
High Country chrome fog light bezels
Color matched grill and trim
Cleared headlights
Switchback LED turn signals: http://instagram.com/p/qImnBoIPLG/
White emblems
2.5 inch front lift
275/60R20 Coopers
All that's left is the chrome Chevy emblem on the grille, then I'm calling it quits until some more LED tailights come out.
Howd you get the ltz/high country chrome bumper piece on? I want to get that and the chrome fog light bezels after I get bumpers color matched
By cleared, he means he removed the amber turn signal reflectors…
Thanks, I wanted black wheels but did not want to black out all chrome and color match handles, mirrors etc so I found a set of smoked chrome wheels that I think is the best of both worlds.
Hypertech Max energy tuner
AFE power momentum gt pro 5R stage 2 intake
Borla dual straight black powder coating exhaust
Lexani LSS10 24" on 305/35 Nitto tires
Retrax Pro cover
Cargo and side step LED lights
Valentine One Radar
10.4" TV inside console
complete system upgrade
Kicker KSC speaker on all doors
Blackout tint
Retrax Pro cover
Valentine One Radar
Blackout tint
How did you blackout your tail lights?
Just put on the new wheels and tires yesterday. 20" Black Rhino Sidewinders and 295/55/20 Nitto Trail Grappler M/T. Now I just need a wash..
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
