Put a new grille on mine last night. Complete with an oil change.
How much did the body match grille run you if you don't mind me asking. I want to body match the grille, headlight trimming and bumpers. I don't like chrome
Hey man! I got mine for $275 shipped. If you Google it it'll come up with a site called Chevy parts. It's listed as $245 and it was $30 to ship.
Got a white one for sale. Brand new and from shop Chevy parts also. Summit white
I'll take $200... Never been installed...
29d892231176af98d62233177624ca6b.jpg1dc6107ad3dd39418add642f74757c8e.jpg180651e0b5ea23f409594077328aa01a.jpg88a8af70ea9c228ea839eddbf82b6ea5.jpg
28 and 28 Life....
28 and 28 Life....
Pm'ed You! ... Wanting a shipping quote..
I'm new to this forum, but not new to Silverado. My new 2015 LTZ Silverado - keeping it stock ;)
My Old 95 Siverado, before it was dropped and painted
after
That's what I thought.. Would save me about $45.00... Hope shipping isn't to much
If shipping under $30 you'll be saving even more. If you have any questions about removing the old one hit me up. I realize there's a thread for it, but I found it easier to just explain it. Just PM me.
Thanks I appreciate the willing to help me out with removing the grille.. I got that covered.. Its not to hard to remove, I had to remove it once already when I put in my OEM LTZ headlights in.. The truck only had like 259 miles on it before I started tearing it apart... And if I do get the grille then my chrome LT grill be up for sale...
Edited by thrasher2010
Oh that sucks. Yeah, it's okay once you get the bumper trim off. However, up until that point it's a pain. I may have to pop it off again if I put a light bar on.
I checked and people are selling the chrome LT grille for almost as much as a new one on eBay.
Hopefully I can sell it, I still have my take off LT headlights.. No one seems to want them... When I traded my last truck in on this one I had so many parts left over that I'm still trying to get rid of ... Oh and I have the middle jumpseat for sale too..!
Oh dang. That's a lot of $ just sitting.
28 and 28 Life....
I'll take it from you, I saw your add on Craigslist a while back and I messaged you but never got a reply.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
