I vote to remove all together. You really don't have any black gloss items that it would accent with. I think a matte black would look better than the gloss since it would at least match the side steps. But these tracks really have such beautiful side profiles that removed would look best IMO.
Still need to get around to pull mine, did you use an eraser wheel to get the gunk off?
Removing is probably the best option, makes the truck easier to clean too.
I just used fishing line and then peel pulled up the sticky stuff with my fingers. It comes off somewhat easy. Any residue left I cleaned with goo gone. Then I waxed the area.
Tailgate took about 15 mins or so for the bowtie and then 10 mins for the letters.
2015 LTZ Z71
2 1/2" RC lift w 2" rear blocks
295/60/20's on stock rims
Line x bed liner
Extang tri-flip hard tonneau
AFE performance cat back
MIT intake tube and high flow filter
What's your mileage like?
I don't know just yet. I would imagine it's going to drop a couple mpg's but not much more than that. It definitely stays in v8 more now.
Sure is 2014 All Terrain.
6.2l
8' BDS Lift W/ 20' XD Riot wheels wrapped with 35' Mickey Tompson Degans
Custom True Dual Exhaust
K&N Intake
Throttle Body spacer
Edge CTS Evolutioin 4 stage programmer
Aftermarket Grille
2015 tow mirrors
Tinted Headlights
Bull Bar.
26' RTX LED Light bar (Bull bar Mounted)
Rigid Industries LED Lights in Fog light housings (Also Tinted)
Tinted Tail lights (Not to Dark) with Reverse lights left untinted.
Tinted 3rd LED Break light
Real Time GPS Tracker/Blackbox with backup battery with a 2 month life span when main battery is disconected.
Hidden Kill switch to prevent theft.
Are those N Fab nerf bars?
Little bit of sibling rivalry. I bought my Max Tow 6.2 the day before my younger brother bought his 5.3 All Terrain
  • Like 5
Very nice Coach!!! Looks like my slt cc butane is white. Same rims and everything.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,743 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
