What are the specs on your setup?
Thanks I figured it out and thank you!
Your truck sits PERFECT. Did you add bigger blocks to the rear and upgrade the control arms in the front. If you don't mind how much did you get your fox for and where from.
Edited by MPH Jr
Hunter21, what is your complete setup? Wheels, tires, and suspension if you don't mind?
This is exactly what I want for my z71 that's coming.
Edited by 440hsp
Thanks man! I didn't add anything to it just put the shocks on.. Later on though I want to upgrade the control arms. I got the fronts on a 10% holiday discount from offroadwarehouse for $1425 and the rears I ordered from butches speed shop here in vegas for high $800.
These are the fronts:
http://www.ridefox.com/product.php?m=truck&t=shocks&p=10&make=GMC&model=Sierra%201500&year=2014-2014&position=Front&ref=willitfit#fitguide
Rears: (for some reason though it's a different part number than what fox lists)
http://www.ridefox.com/product.php?m=truck&t=shocks&p=7&make=GMC&model=Sierra%201500&year=2014-2007&position=Rear&ref=willitfit#fitguide
Wheels - Methods Race Wheels 17" 101 Beadlocks
Tires - BFG KM2 35"
Shocks - I gave the link above.
huntster... OH MY
That's beautiful!
Thank you! I was kind of skeptic on going with 35's but liked it a lot after I put them on.
Edited by huntster21
You didn't use any suspension upgrade like body lift or anything?
But do the fox's lift the truck? I didn't think you could put 35's under the factory lift.
Edited by 440hsp
Yes, Fox coilovers lift the front of the truck. I believe it's adjustable between 2 and 3 inches of lift.
That's awesome. Just what I need!!!
I'm probably gonna go this route.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
