Thanks hunster
No problem.. you just will need to trim the front fender wells.. Im gonna buy some wheel spacers to help also.
Nothing wrong with the single cabs. Actually it's kinda refreshing to see them for a change. :thumbs:
  • Like 3
Thanks man for the quick reply. Mine is gonna be silver. Gonna do a black and silver mix with this truck. I think it will look just right with these shocks under it. How high did you adjust the shocks? 3 in. ?
You're talking about the fender well liner, right? Or metal?
Not mine, but saw this at Outlet mall a few weeks ago. Only pictures I could get before my wife dragged me away. 4e1210fe687948fc3712ab554dd9dadc.jpgb61395985405316bd924217a1722dab3.jpg
Just the fender liner
I left it at the stock level on the shock collar which is a little more than 2in, but going to go back to the shop to have them lower it some to raise the front. Because after a month on it the front is a tad lower than the rear now.
Edited by huntster21
Yeah it settled some. My coil overs did the same on my car.
I wish I knew how he got his light bar to sit flush with the grill like that.
Looks like he cut the grill perfectly
Not mine, but saw this at Outlet mall a few weeks ago. Only pictures I could get before my wife dragged me away. b61395985405316bd924217a1722dab3.jpg
I dig this grill with the LED bar.. do you or anyone else know who makes it? Or is that LED bar retro-fitted?
I've never seen anything like it. I think it's retrofitted. I wanted to get a closer look, but wasn't able to.
That light bar is awesome! If anyone finds out more details on that I would love to know!
McGaughy lift set at 8"
Edited by SAM-3%
  • Like 3
Even when she's dirty, she's clean [emoji41]
C03C924C-365D-4A22-A4B4-2C5E6F7581D6_zps
  • Like 3
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
