New wheels and tires installed today!! Loving the KO2 all terrains.
Edited by SULLVERADO
Hey railroad guy, I looked up the leveling kits. Did you use the front shock spacers? Only seen those as 1.5"
I made a mistake on my post it is the 2.25 ready lift for GMC and Chevy Silverado 1500 2007-2015 the sku# is 66-3085
Had to replace the right headlight. Barely 3 weeks old and this. A large rock bounced up from the interstate and cracked the plastic right down the middle. At least it was only the headlight. Found a brand new replacement for 250. Cheapest one I could find. Pop out and pop in. It took me about 45 minutes to do. Had to take grille, fan cover, and painted plastic bumper piece off. Gave it a bath after. Got my BFGs in and waiting on the new silver all terrain grille. Should be here Monday. Wished I would have waited until I got the grille in. Then I could have popped the grille in while I did the headlight. Couldn't wait.
Custom sport Z71 and LTZ Z71
Good looking rigs. I miss my 14 silverado. Had it paid for too. Had an itch for a sierra. Just had to get one. Oh well. I sure like the custom sport cc silverados.
Colrise, where did you get your grille from. I want the metallic silver all terrain grille but couldn't find it on ebay?
What size tires ....looks good
Edited by -Wood-
Snapped a half decent pic after giving it a bath this evening..
I found it on one of the oem GM parts websites. I think it was GMPartsdirect.co. You can look for it on any oem GM website. Part # 22910415. It is the quicksilver painted one. There is one ebay I think.
They are 275/70/18. The guy at the tire shop said it was a true 33" tire and only .25 of an inch narrower than a 285/65 that I originally wanted. Very happy with them
Looked on ebay. Only found a black one. Went on gm parts direct and can't see pictures of the grille or tell what color it is. Lol
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
