Where did you get your replicas from? I'm still waiting for someone to develop a levelling kit to properly work with the Magneride suspension so hopefully it will all fit as is
Ebay.. All kinds of reps on there
Just joined this forum! Just bought a 2015 Chevy Silverado1500 Z71 4x4 Crew Cab in Silver Ice Metallic. Loving it :driving:
Welcome!! Beautiful truck
Already tinted by my son! 3M Color Stable 20% Tints - front windows.
Thanks! I didn't like the color when my son took me to the dealership as he was the one who found it, but after seeing it cleaned and waxed I loved it!
Just picked up my quicksilver metallic today. Love it96ac8f2bcc694d0941fea64280ad3433.jpg
644529a395d1cc8780506eab1928a101.jpge80a95251d86099fd589b03305377fd2.jpg115051146f388e6a8b5cb2ec61b68b5e.jpg
2014 GMC BAYOU 6.0 Sierra 1500 SLE 5.3 Liter V8
Sent from my iPhone using TapataI
Is that an aftermarket grille?
What lift do you have.....also that grill is pure awesome
My truck is a custom build by the dealership, hence the name on the truck bed. It's a little hard to see in the first pic, but it says 'SLX Bayou Edition'. This is the Bayou 6.0 as it has a 6" lift.
Lift kit, wheels, & tires are all Pro Comp, also has AMP Research Power Steps, MagnaFlow Cat Back Exhaust with twin rear-exit pipes, and a sprayed in bed liner with a 1" raised letter GMC on the front bed rail....very cool looking. The grille with 6"x25" GMC letters are also custom built by the dealership. Great part about it all being built by the dealership is that the aftermarket mods are all covered under the new truck warranty!
My first pick-up truck, bought specifically to haul my ATV out to my hunting camp where I put the 4-wheel drive to good use!
Edit:
Damn.... Sooner later I'll figure out how to post a Reply correctly! This post was to answer Chevy2tuff2006 & 5RWill.
Edited by Bayou 6.0
Truck all cleaned up with the new side exit exhaust.
Very nice! I want those damn headlights!
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 420 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
