And now...... back to the OEM wheels (with low profile tires of course). The big wheels rode like crap to me so I went back with the stockers and small enough rubber so I don't have any more clearance issues. I'll do something to the wheels soo enough to make them a little different but for now I'm just enjoying the plush ride.
I would keep the stockers. Look much better IMO.
post-131214-140331704356_thumb.jpg ill settle for my parking lot as a background. ...ha ha
Sent from my SPH-L720 using Tapatalk
Found some old sunshades in the garage. Bought these a while back as a joke, decided I'll use them until I get some tint.
I don't think they look too bad haha.
Your truck looks like a dog lol
5.3 SLT
AVS Window vents with bug knocker
RC 2" waiting to be installed
EXTANG Trifold Hard Cover
Tinted front
Debating to debadge
3 miles odometer when drove off dealer lot
1100 miles now without 1 single issue, keeping fingers crossed lol
Drop in bed cover
Edited by Durtywimmin
Just a better pic, out of the driveway…
Can't wait for the 2" levelling kit to get here…
Finally figured out how to post...
2.5 front only leveling kit
295-55-20 toyo mt's
Color matched front grille surround and tailgate latch
Sent from my SCH-I605 using Tapatalk
  • Like 3
My 2014 GMC Sierra 4x4 with 20" Fuel Maverick with 275/60/R20 Goodyear Duratracs, Pro Comp front level kit, and Borla dual exhaust
  • Like 7
10441373_10101117814258362_7135665583357
Put a coat of Ice Wax on yesterday, did meguiars traditional wax a couple weeks ago.
im just wondering what is the point in lowering a truck? i mean you cant haul anything now, it pretty much useless for what it is intended for now... unless it runs a 10 second quarter mile i don't understand the point in it?
How do you figure it can't haul anything? I've haul stuff with lowered trucks in the past, and in some cases they performed better then the stock counterpart. I use to haul my Drag truck to the track with a lowered 97 sierra, it did great. As I see it lowering a truck can make it easy to get things in and out of the bed too, depending on what you need to get in the bed, such as a motorcycle (less of an angle to go up). Lowering a truck doesn't necessarily alter it's capacity, in most cases it just alters it's ride height…
The LSU plate just makes this truck look bad...
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 461 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
