Maybe this will appeal to the masses a little more. My truck lowered just a little beside a friends truck that was raised up just a little. Pretty decent comparison if you ask me...
I De - badged and dumped the exhaust.
More pics please! Is that rear chevy badge just glued on? or were there locator holes you had to fill in?
Also how did you dump the exhaust?
LTZ 4x4 5.3 RC leveling kit 275/60/20 Terra Grapplers….waiting on Bak Flip bed cover and Go Rhino Dominator II steps.attachicon.gifIMG_0076.JPG
Did you get your side steps? Pictures? Just bought a white double cab; debating on whether I want OEM style steps or the dominators.
The rear badge is glued on. No holes to deal with. I removed the stock muffler and had a flowmaster pro 10 welded up. Then I cut off the rear resonator and extended the pipe over the rear axle. I will take a pic for you and post up later.
my new Denali getting a bath
7296D358-0132-4C1A-833B-3D2B6327F4B0_zps
Thats a lot of suds, what do you use?
good to know! I am thinking about de-badging and that makes life way easier. I did the muffler delete to mine and welded in a straight peice but its still way too quiet. thinking about getting rid of the resonator, and that flappy valve.
6oz of Adams Car Shampoo in a 36oz water bottle connected to a MTM Hydro foam cannon on my pressure washer :thumbs:
Edited by Z71_Denali
More pictures/specs of your buddies truck?
Yours is nice too though.. Haha
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
