my new Denali getting a bath
7296D358-0132-4C1A-833B-3D2B6327F4B0_zps
you know you should never clean a vehicle in the sun Right? by the time you get to its going to be dry..
Edited by upsfeedr
your comment is valid if i were to use a soap like Dawn or cheap over the counter car wash liquid that's not pH neutral.
Adam's car shampoo is pH neutral and completely safe to use in direct sunlight. it washes away without any problems when it dries. i also use softened water on my initial rinse and RO water on my final rinse; i have a water line in my garage tied into the home water softener and RO tank because the tap water here is terrible. never had a problem with spotting or degradation of sealant/wax on the finish. i do pull into the garage to towel dry though. direct sunlight is unavoidable here except at night, and i'm not one to wake up early or stay up late to do a wash :thumbs:
  • Like 7
Silverado LTZ with 6.2 and 3.73 rear end. BDS 4 inch lift with 295/60/20 Toyo open country AT2 Extreme's on Fuel Maverick wheels. Still rides great and has no rubbing issues and no trimming.
rotten tomato, do you have any pictures down the side? Does that kit require a spacer in back to match front track width or does the front not get pushed out?
Good lookin truck!
New here, this is my 2014 Silverado LT
20140612_144158_zps78391173.jpgIt's a 4x4 with the 5.3 and 3.42 gears, exactly what I wanted. The 2" RC levelling kit is on it's way and just working on which tires and size I want to go with…
And now...... back to the OEM wheels (with low profile tires of course). The big wheels rode like crap to me so I went back with the stockers and small enough rubber so I don't have any more clearance issues. I'll do something to the wheels soo enough to make them a little different but for now I'm just enjoying the plush ride.
What size wheels and tires did you pull off?
Those stockers look real nice.....plush ride is super important especially on a pricey truck....
Sent from my SPH-L720 using Tapatalk
Link
Edited by Spedee
  • Like 4
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
