After several shipping delays, yesterday I finally received my new 2014 Silverado LTZ Z71 Crew Cab.
Looks great - very similar to mine except I don't have the sliding rear window. Washed it with Turtle Wax Quick and Easy because of the hard water stains, still left stains but not as bad, and waxed it again today with Maguires Quick Shine. By the time I was done, the pollen had already covered the first side I did. Doh! Darn gravity! Going to try the Collinites 925 liquid carnuba wax I use on my boat. I'll seal it before the winter and wax it again then. All the forums say it's the same as the car wax just different container. Black sure is hard to keep clean :-|
Edited by Mad Max
Just some crappy cell phone pics in the driveway. Just put a RCX 2.5, 275/70R18 Duratracs, and OEM color matched handles and mirror caps. Oh, and I took the air dam off. I MIGHT chrome the wheels. Maybe.
YByfqSJ.jpg?2
sTs6Pi3.jpg?2
Go06smT.jpg?1
  • Like 5
YByfqSJ.jpg?2
sTs6Pi3.jpg?2
Go06smT.jpg?1
Any rubbing with those duratracs? Clean setup for sure. I would not chrome the wheels.
Edited by tsdrumm
Nothing that I have noticed yet. No rubbing at full turn (even with the air dam on).
I have seen others put a little bigger tire on the 2.5 level, but I can't imagine how without rubbing. I didn't have to trim anything and I'm happy with the size. These are my first duratracs. I got them after a lot of research and reviews. They are smooth, but surprisingly louder than the 37" nitto trail grappler MT's on my jeep! I don't have close to enough miles on them to make an honest review, but my first impression is louder than I expected.
Edited by BrownstoneZ71
2014 Sierra.
6 inch Fabtech lift
35 Mickey Thompson Baja atz p3
20x9 AE wheels
Dual exhaust
Fender flares
And a little camo for looks haha!
Edited by DCobb
YByfqSJ.jpg?2
sTs6Pi3.jpg?2
Go06smT.jpg?1
Looks perfect IMO. Did u use the 2" block or kept the factory?
Sent from Tapashit
2014 Sierra.
6 inch Fabtech lift
20x9 AE wheels
Dual exhaust
Fender flares
Man that is sweet! What did it cost you to get the flares color matched?
Also you need more Max4. God made hydrodipping for a reason! :cheers:
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
