The Denali replaced the All Terrain due to issues. My problem was how long and repetitive issues. It did not vibrate but did have the exhaust issues in addition to others.
Secondly the new Denali I am leaving the stock tires on for now and the truck is actually smoother than the old one. Only put on new tires on the old one for the all terrain look and towing.
So far I like the replacement better. The iridium is killer!
Only thing is the new collision detection seems worthless, however like the lane departure.
Sweet, I ordered the same...hopefully I get to pick it up here I'm the next week or two! Shipped from Mexico on Tuesday. How do you like it? They are changing out my denali rims for the all terrain ones at the dealer for me as I hate chrome rims. Jealous.
I think the iridium with cocoa interior is a great combo. I have had all black interiors before and this cocoa/dune is really nice. Secondly the truck was sitting in the sun all day, the seats and interior were much cooler than my all terrain black would have been.
I don't mind the chrome denali wheels, but really did like the look of my all terrain.
Only one I have so far with my little buddy helping me wax it.
5DD986EC-027E-4654-9815-6C445E958F66_zps
C51F4CE8-BAAA-4486-AD69-969F9D8C8AA8_zps
do u have a Link to where I can get those?
Sent from my SM-N900T using Tapatalk
These are the newer version of mine which are touch screen
http://www.amazon.com/Concept-CLD-903-9-Inch-Single-Headrest/dp/B00BQMM1H6/ref=sr_sp-atf_title_1_1?ie=UTF8&qid=1401117466&sr=8-1&keywords=CLD+903
If not just search amazon for CLD-700
The D I believe denotes the DVD player. BOTH my head rests have their own DVD players. For the $ I think they are a good buy.
very good price.
Here's my 2014 Sierra SLT. Traded in my red 2012 6.2L for it and I couldn't be happier. This truck is so quiet and smooth and has just about every option you can think of. Truly impressed.
Edited by CL8N
Is the new one a 6.2? Edited by TX14Z71
No, I just went with the 5.3L this time around. I had headers, stall, gears, tune, etc. all done to the last truck. I'm done trying to make them fast. Just going to try and enjoy the smooth and quiet ride for a while. :)
Sent from my SM-G900V using Tapatalk
  • Like 6
I'm not familiar with the area since we live in Humble, but I bought it at Beck and Masten North.
Looks Great! Are the calipers painted or snap on covers?
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 461 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
