I find it strange that they would remove any bolts, the bolts and nuts come in a bag. I didn't put mine on until right before I installed them. Unless they also install them after paint, but I'm too cheap to pay people to do that.
I already had them on my truck installed before I decided to get them painted.
Truck looks good. Don't see many with bed rails.
Any winter problems? Frost, snow, salt...?
Sent from my iPhone
I used to have them on my '06 Mega Cab with a 6" lift and I never had any problems with them at all in the winter
Nice to hear. Do you have mud flaps (to limit snow and salt intrusion) and where are you located?
Sent from my iPhone
Nope no flaps. And also had 37" Toyo M/Ts. I lived in Utah when I had them but traveled a lot from Utah, Colorado, Wyoming, Idaho and Montana.
My new 2014 Silverado LTZ crew cab, I need to add some nice nerf bars/running boards. Anyone have any suggestions?
Amp PowerSteps are great.
Not sure where you're located, but I'll make you a killer deal on my factory steps. attachicon.gifIMG_20140810_193909727_HDR.jpg
I live in Columbus, Ohio. What kind of deal?
Per gm ordering guides Laguna Blue Tintcoat for the vette and Deep Ocean Blue Metallic for the silverado are color code G1K so they should be the same color
Do you have a link where you found this? I'm really disappointed with the Deep Ocean Blue pictures on the 2015 Silverado site, looks nothing like the Laguna Blue.
I do have a link, but as I was double checking it appears I was reading with my head too far up my ass. The color code isn't the same, sorry about that...
Silverado
http://www.gmfleetorderguide.com/NASApp/domestic/proddesc.jsp?year=2015&regionID=1&divisionID=1&type=0&vehicleID=16823&section=col_trim&page=9&butID=3
Corvette
http://www.gmfleetorderguide.com/NASApp/domestic/proddesc.jsp?year=2015&regionID=1&divisionID=3&type=0&vehicleID=15943&section=col_trim&page=9&butID=3
Wow, so lots of "crap" hitting the steps, and NO issues?
Sent from my iPhone
Thanks I do appreciate it, Edited by snebj25
Sent from my iPhone
Oh yeah I've had lots of stuff sticking on there and didn't have any problems.
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 436 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
