Yes this backup camera on the '14 Silverado is much Lower resolution than the last two cars I have owned which had backup cameras (neither were Chevy's). For the most part it seems to work and I can see, but the biggest problem w/ the low resolution is that once it gets even a little dirty you are totally blind. At least on the higher res cameras I've had when they get dirty you can still make out stuff in the screen. That said, the Silverado's camera seems to do better backing up into the sun than my other two cars.
Edited by Nickshu
The other big problem is it takes a long time for the camera to night/day mode to update when backing out of the garage. I can back all the way out and by the time I'm putting it in drive it updates and you can finally see something.
I agree... The sharpness is quite bad compared to my wife's 2008 Honda... But the BIG screen makes a huge difference... If I could have the big screen and a crisper video... that would be awesome.
I want to install a quick connect so I can unhook the camera from the tailgate and connect a different camera (On the back of my camper) once I'm hitched up.
I found the schematics, I just need to do a little testing of the pinouts. It will be interesting to see what a different camera looks like on the same display.
Anyone else notice the camera stays on for a few seconds after putting it in drive?
Its like...a CRT television with like 480p resolution. Even on the 4 inch MyLink the camera is not better. Needs a higher res camera.
Yes
I have a 2014 Sierra and I agree that the camera quality is horrible.
I just use it to keep from hitting something or someone. Seems adequate for that.
for the most part. I have trouble seeing where my trailer hitch until im about 5' away from it then I can see it.
if someone made a higher res camera I would buy it in a heartbeat!
Sorry if this is a dumb comment, but... Does cleaning the lens help? Maybe there is a layer of wax or oil over the len?
I just had my camera replaced by the dealership. NO improvement!
Perhaps a 3rd party will provide a HD camera replacement.
HD camera or any other higher resolution camera will do no good when the infotainment screen is the controller of the end result resolution. So unless you have a way to change out the infotainment screen with one with higher resolution then a higher resolution camera wont do a thing.
I already posed this question to the engineers when I was working on the radio process.
The screen is not the problem. The resolution of the screen is very good.
Gringo
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
