Damn Transmission….
GMC-AT
how does it save gas by downshifting ? The RPM's go higher every time... seems like it would eat more gas.. versus when you left off the gas.. RPM drop to near nothing..
  • Replies 72
The rpm is not going up from inducing extra fuel its going up from the tires rolling.. There fore when you hit the pedal to go again your not giving extra gas from idle to say 1400 it's downshiftimg to bring rpm higher therefore when you get in gas in theory no extra pedal effort..
Rpm matching.
The rpm is not going up from inducing extra fuel its going up from the tires rolling.. There fore when you hit the pedal to go again your not giving extra gas from idle to say 1400 it's downshiftimg to bring rpm higher therefore when you get in gas in theory no extra pedal effort.. Rpm matching.
Good explanation.
Good explanation.
tried lol
Sorry you don't like the way the trans works.
The trans is allowing the vehicle to back-drive the engine when coasting. This allows the engine to use very little if any fuel when coasting. You see RPM increase because when the engine speed gets low enough in a certain gear, the trans needs to downshift (while still backdriving the engine and still not using much if any fuel) to slightly increase the engine speed to keep the eng speed high enough to make sure that if you step on the throttle, you're in a decent gear and RPM to accelerate.
When the engine is being backdriven like this, it uses less fuel than just dropping to idle.
Hope the explanation helps.
TF
That does make sense when you think about it. I know they do every possible thing to squeeze the most MPG..
I still hate the trans though..
I hate how mine doed exactly what your saying.. It feels like it chunks... And the -1-2 shift feels like it slips to second
SAME HERE!!!! tjhought it was me...
drives me nuts
tried lol
it was good. for real. :thumbs:
For everyone complaining, im sure a custom tune will be able to tune this out. If it bothers you that much. Tune it out.
This thing is going to dealer Monday my 1-2 shift slips than jams in..
In traffic the v4 to v8 clunk.. Wtf... I am starting to miss my f150 with this transmission
Just wait for the 8 sp tranny...that will be fun. You really hate to tune a new truck and risk powertrain wty problems. My 09 trans function has been a pita since about 1000 miles. I held off because of wty on power train. Finally tuned with about 6 months to go on wty....
If tranny not setting any codes and not easy for dealer to replicate the issue, you are stuck. We road many miles with scan hooked up and service mgr could not replicate. I would leave the dealership and it would act up within the hour.
I would now try just the range to cut off AFM and see if that helped. If not and If dealer not able to replicate issue, then I would give it a yr/12,000 or so and see if gm issues a fix. If not, go see a good tranny shop. If they find nothing then tune it. My 09 is nice with an 89 oct tune.
This thing is going to dealer Monday my 1-2 shift slips than jams in.. In traffic the v4 to v8 clunk.. Wtf... I am starting to miss my f150 with this transmission
How the hell could you miss it? The trucks ok but you get craptastic engines. Ones a unreliable, fuel drinking pig that sounds like a camry with hairdryers, the others an anemic dog with junk car only DOHC. Ford used to make great motors until they went the modular route, nothing but problems since then.
That 5.0 is a damn good motor.. The thing has more power than the current 5.3. Low end not as much but wot the 5.0 kills this.
The transmission in this truck is jerky. Ever since the reflash.
I keep finding issues as the day goes by
1. Back left seat rattles unless weight is on it or up.
2. V4 TO V8 is rough.
3. In v4 mode truck surges and vibrates under 50mph
4 . top end passing power not as much as the f150
5 . steering wheel is made of cheaaaap material. Ive knicked the wheel 2x and now have a nice mark from my fingernail which drives me crazy now I know its there.
6. The truck is very quiet when driving.. Except hitting rumble strips before the bridge i drive every day. (wife and 2 friends mentioned it also) 7. Tires need re balancing.. (could also be #6 problem to.. Hard ass tires)
Those are my irritations
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
    • I was a Chevy guy for years, then switched to GMC because I liked the looks better.  I'm actually thinking I like the Chevy looks better than GMC for the first time in a lot of years.   One thing I know for certain, the new GMC dash is hideous!  Chevy wins this one!
