07 LTZ vs 11 LT
Hello all,
I am buying a new truck and can't be more excited. I found two that I love, but I am having a hard time deciding.
I found a 07 crew cab LTZ with 64k and a 11 ext cab with 80k. I do not care about the cab size, and although the loaded features are awesome, I am most hung up on the 6spd vs 4spd transmission, mainly for the gas mileage boost. Lack of bluetooth and USB in the 07 also is unfortunate (I know there are aftermarket options if i seek this out). The loaded features and lower mileage make the 07 appealing though. Any opinions/insights would be greatly appreacited. Thank you!
'11 would still be covered under warrenty as well. Personally the downfall for me would be the Ext cab part. I dont think I could ever go smaller than a crew now (personal pref.)
I have an 07 crew I got with 87k miles LTZ, I love it so far and I have 110k miles on it, I know my gas mileage used to be right around my stepdads until i lifted it, and he has a 2013 Tahoe with the 5.3 6 SPD
I think the first thing to consider is what your needs are. Do you have a family or do travel that would make a crew cab a wise choice? Also, how long do you plan on keeping the truck? That might help you think about which has the options you'll need or if you'd want to add them aftermarket if you're going to keep the truck a while.
Thanks all! No family, so like I said, the cab size doesn't matter to me. I'll take it either way.
I would hope to have the truck a while. However, knowing me, I'll probably try to get a hold of a '14 in a few years!
I guess my main concern were the mechanicals--if the differences between the transmission changes and noise insulation were just worlds different that I'd be crazy to go pre-'09.
I would go with the '11. The 6 speed will deliver better acceleration and fuel economy, and the 2011 engine has had some updates to counter the AFM issues that are fairly common in the 2007's. The extended cab is plenty big for my needs, but you should investigate that further.
I just traded in my '07 SLT crew (the same as the LTZ as far as I'm concerned) for a '13 LT ext.
Couldn't be happier. For several reasons.
-less technical gimmicks means less headache (e.g. rear sliding window... :cold: )
-it's not a "first production year" truck
-with the "Thunder Edition" still nicely equipped and meets my needs
-6-speed trans (that's what I like the most)
-ext cab is less room to warm up or cool down and my kids are grown up and I don't have a dog (yet...)
and so on.
so long
j-ten-ner
EDIT: ...and I have a bigger truck bed... :thumbs:
You all are awesome, thank you. The 11 might not work out, but I will keep looking. They are trying to make some deals with the 07, as nice as the upgrades are post 09, I am taking comfort in the fact that the 07s are still solid trucks :)
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
