New here from Los Angeles
Bad Ass Silvy
Hey everyone, name's Aaron, 33, been a longtime member on SilveradoSS.com since 9/06. No stranger to the forum world. Joined up over here since there is a meet coming up in Dec. so figured I say hello.
The truck:
05 Silverado, VHO Edition, factory built with LQ9, 65E, 14 bolt G80, Sunroof, Bose, etc.
Mods:
Radix MP 112, 2.8" pully, 60 lb. injectors, some headers, street tuned for 30 hours (runs pretty good)
3/4 drop, C-notched frame, SS powder coated 20's, some pieces blacked out, etc.
I am an extremely humble person, always there to help if I can provide solid valid answers, and the 1st to ask a question and admit I don't know something. So a person of integrity with a sense of humor :)
Thanks for reading.
Welcome to the site. You now join the ranks of myself, kraus, desrtrat, diggerdan, and bad bowtie (2) who are members on both
Sent from my Samsung Galaxy S4 using Tapatalk Pro
Good to know, look at you "Moderator" - nice!
Im not the moderator to worry about
You had to use the stripper pic....
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
