Connman Posted May 28, 2014 Posted May 28, 2014 I really like those tires. I'm thinking of trying to run 325/60r18 on a level kit with those tires once I get my truck. Probably gonna have to do some trimming. I wouldn't go that big. I'm barley making it. I've got a +10 offset and my tires roughly round out to 33x11.5. That's almost 13" wide isnt it? Just my opinion but that might look a little wide even if u make it fit with trimming, which u will definitely have to do. It is preference so if u really like that look go for it, but I'm just about hitting the sway bar as well. These truck don't fit a much bigger tire with the level kit because of the way the wheel wells are. Just go with a 6 inch lift and 35's, I'm already wishing I did but didn't have the guts on a brand new truck!! Maybe when I need new tires I'll go for it, haha.
SF Silverado Posted May 30, 2014 Posted May 30, 2014 ok so forgive me for beating this dead horse a little more. Has anyone ran a -12 offset wheel with 295 55 20 tires and have any problems?
KUUG Posted May 30, 2014 Author Posted May 30, 2014 ok so forgive me for beating this dead horse a little more. Has anyone ran a -12 offset wheel with 295 55 20 tires and have any problems? To my knowledge I haven't seen anyone with this set up. What lift do you have?
SF Silverado Posted May 30, 2014 Posted May 30, 2014 To my knowledge I haven't seen anyone with this set up. What lift do you have? Sorry I thought I put that in there. I have a rough country 2.5" level kit
KUUG Posted May 30, 2014 Author Posted May 30, 2014 Sorry I thought I put that in there. I have a rough country 2.5" level kit I can guarantee you wont fit that big of a tire on a -12 offset. I tried 30/55r20 -12 offset with a 2.5 and I rubbed where I had them take it off. After I added the 1.5" body lift I only have slight rub in reverse. If you read through my posts I explain my trial and error in more detail. If you're wanting that look I would recommend trying a 0 offset, that might get you close but I'm almost certain you would have to stay with stock to fit that tire. People on here are fitting it with slight rubbing on a stock offset...
SF Silverado Posted May 30, 2014 Posted May 30, 2014 Thanks for the info. I read through the post on here but must have missed something. I appreciate the information. Ed
allterrain14 Posted October 8, 2014 Posted October 8, 2014 Ok guys I have read the entire post haven't seen an answer to the set up I am getting ready to order. Wanted to get some input. Looking at a XD Misfit +0 offset. Will a 305/55/20 fit with no rubbing? Or do I need to go with a 295/55/20. Looking at putting fender flares on so wanted a tire that wasn't tucked underneath. Truck Set Up 2014 GMC All Terrain (Z71) 2.5" Rough Country Lift
blackout07 Posted October 8, 2014 Posted October 8, 2014 I can guarantee you wont fit that big of a tire on a -12 offset. I tried 30/55r20 -12 offset with a 2.5 and I rubbed where I had them take it off. After I added the 1.5" body lift I only have slight rub in reverse. If you read through my posts I explain my trial and error in more detail. If you're wanting that look I would recommend trying a 0 offset, that might get you close but I'm almost certain you would have to stay with stock to fit that tire. People on here are fitting it with slight rubbing on a stock offset... Ok guys I have read the entire post haven't seen an answer to the set up I am getting ready to order. Wanted to get some input. Looking at a XD Misfit +0 offset. Will a 305/55/20 fit with no rubbing? Or do I need to go with a 295/55/20. Looking at putting fender flares on so wanted a tire that wasn't tucked underneath. Truck Set Up 2014 GMC All Terrain (Z71) 2.5" Rough Country Lift See the above post. Your talking a minor difference in offset so the same will apply. I'll say bith sizes you listed will likely rub some.
Ljkastner Posted February 17, 2016 Posted February 17, 2016 I have a 2014 GMC Sierra 2wd with a 2.5in leveling kit and a friend gave me his old tires temporarily. They are 305/55R20 Toyo Open Country's. I need to know if I will be able to fit these tires on stock 20" rims. A little rubbing is fine, and don't want to trim anything. I just need to know if they will rub bad or not or even at all. Thanks for all the help y'all can provide to me!!
Bcmking3 Posted June 25, 2016 Posted June 25, 2016 OK, so I am confused as ever - I am getting ready to install a 2.5" RC Leveling kit with stock 20" rims on my 2015 All Terrain - can I run 275/65/20's which is 34" tall without any rubbing issues? I do not want the tires to rub but want to find the biggest tire with this set up I can run without issues or adding spacers, etc.
kdickey05 Posted November 18, 2016 Posted November 18, 2016 I also have a 2015 Silverado 1500. I put a 2.5" Rough Country Leveling kit in it and am trying to figure out wheel and tire combinations. I'm thinking 275/60R20 Wrangler Duratracs with 20x9 +14 or +20 Fuel Mavericks. Does anybody have a combination with these dimensions? I won't want any rubbing and don't necessarily want to trim anything. Any help would be greatly appreciated! Thanks!
Jaycreek7908 Posted November 21, 2016 Posted November 21, 2016 I'd love to be able to run 35's like I did on my old F150 but I just don't wanna worry about cutting the front diff on my super clean '14 LT
quise2024 Posted November 22, 2016 Posted November 22, 2016 I also have a 2015 Silverado 1500. I put a 2.5" Rough Country Leveling kit in it and am trying to figure out wheel and tire combinations. I'm thinking 275/60R20 Wrangler Duratracs with 20x9 +14 or +20 Fuel Mavericks. Does anybody have a combination with these dimensions? I won't want any rubbing and don't necessarily want to trim anything. Any help would be greatly appreciated! Thanks! Not sure how quick you need feedback but i will basically have this exact setup in a cpl weeks or so. Wheels are on the way and tires will be ordered end of this week or monday. Wheels are a +15 and im buying 275/60R20 Duratracs. Plaon having a 2" level kit installed as well
