I remember reading someone recommended replacing the u-bolt. Don't know if it was this thread or why they recommended it.
thanks, from what I gather, you may run out of threads to reattach the nuts on the U-bolt after the block is removed. So I guess you just buy the u-bolts from a 4x2 model that doesn't have the rear block? But I thought I saw someone on here that the person reused their 4x4 u-bolts.
I thought it had to do with the travel of the newly exposed threads, maybe they can be cut. I can't recall though. Just speculating. :)
It's interesting you would say that. I know there's a lot of opinions on this and other forums. Many saying to use new and just as many saying they didn't and nothing bad happened so I did a search looking for what I would consider a reliable source and came up with this:
HOWEVER, read the following transcript:
SO, since removing the block moves the nut 1" further up the threads you are using virgin threads and should be able to apply the proper torque and have that torque retained. Of course, if you decide to go back to using the block then you need new bolts because you will be back into the area of the threads that were deformed by the original installation. No new bolts needed for this operation, only if I go back to using the blocks.
The re-torque after two weeks perplexes me. Are there guys running around dealer lots re torquing u-bolts? How is it the factory can install them and they are good for years but I need to re-torque?
Perhaps this is due to the explanation above where old parts wear different than new, which seems a bit far fetched to me AND I doubt the movement on the bolt would be more than a few hundreds so you aren't going to get into any significant "new" threads as mentioned above. Since the Truck is all of 2 weeks old I don't think the old parts vs. new is an issue but I will check just to see if there's any truth to the legend.
Has anyone who's played around with u-bolts ever seen them loosen up after a few hundred miles or is this more urban legend than sound engineering?
Here's the original post talking about the U-bolt
Hey everyone, new at the forum..Just got a 2014 Sierra a week ago and installed my Rough Country 2/4 Lowering kit on the weekend, took about 4 hours with 2 ppl. Love the look but there was some vibration. I got 6* pinion shim installed today and all vibrations are gone..
How did you know how many degrees you needed to shim? Also, what is the part # for the shim kit? I have 2" shackles with block removed for a 3" rear drop on a 2014 GMC double cab. Edited by whodatfan
Well since I'm kind of new at this, I did some research on how to measure the angles, and that's what I did..then I read about what other people have done for this kit, and I decided that a 6* would be a good place to start. I measured the angles again once I put the shim in to make sure I got it where I need to be, and right now I'm within 1/2*. I got the shim kit from Summit racing, just search for a 6 degree pinion shim.
I already have 2" drop shackles installed, so how do I determine what the factory pinion angle was? Also, how to figure out how much 3" of drop will change the pinion angle? Does the truck need to have the 3" drop in place first to then measure the difference?
It doesn't matter what the factory pinion angle was, it's what you need to be at after the modification. You have to match it to your transmission angle.
I don't know how to figure that out, but if you drop it further just take a measurement and you will find out then.
With a little Photoshop magic, here's my truck sitting about how I'd like it. Maybe it is 6/8? Don't know. Why do y'all think?
Yeah, that looks like a 6/8. It's 2WD right? I don't think you'll have any problems in the rear with a flip kit and drop shackles... the front will be a challenge. Make sure you go under-size on tires and a pretty high positive offset for no rub. Possibly narrower/smaller tires in front than rear.
Edited by Luster
Fellas I need some help. I've looked all over this site and can't find an answer. Just put maxtrac shackles on my 14 sierra AT. Took about an hour. Dropped hitch and gently persuaded bed seams like everybody does. Installed new shackles. Dropped it off the lift and tightened like Maxtrac says to do. Here's the issue. RR is 1" higher than the LR. So rear end is actually crooked. I had maybe .150 of the "Chevy lean" before I started. I've checked and double checked everything. Loosened and re torqued everything. Check shackles to make sure they were the same also. Clearly I did somethin wrong. Need some help figurin out what!! Sorry if I'm missing a post about this somewhere else. Thanks for the help guys.
Whodat I installed a 4/6 DJM kit on my 2014 and based on your photo 4/7 would prob get you where you want.
Do you think 4" will get his front tire tucked? That's why I said 6... possibly 5.
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
