3 minutes ago, Nasty said:
Im saying free. I dont recall saying anything about buying them off me
Ha well damn I’ll send you a message
Once you get them and install them let me know if they work. My truck squeaks also so I might need a pair.
Ok cool will do
18 hours ago, Shibbby911 said:
Pretty sure the shackles is where the squeaking is coming from ha
Mine rub in the exact same spot
Probably a year ago i did warn people of this.  Mayhe even more. The mcg, belltech and djm lift shackles will not work on our trucks
They'll work, just requires some massaging like anything when it's modified
2 hours ago, Shibbby911 said:
Got mine aligned today
Remind me again what brand you used? Just wondering if you needed camber plates
Hopefully the shackles that are a little longer fix it
What's the verdict? Did the shackles help?
21 hours ago, Shibbby911 said:
I haven’t got the shackles yet
Im really sorry. I messed up on your zip code and they came back to me. They went back out yesterday.  Stupid mistake on me. They're on the way
Oh dang man it’s cool don’t be sorry ha
Let me know what you think when you get them. I'd like to know if they're any longer and/or skinner than the Belltech ones.
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 505 Guests (See full list)
