18 hours ago, Dinner said:
Let me know what you think when you get them. I'd like to know if they're any longer and/or skinner than the Belltech ones.
They are longer than thr belltech ones by about 1/2" or so
Tons of info in this thread - I've read through most of it, but didn't find the answer, so I thought I'd ask before I pull the trigger.
I have an '18 Denali with factory 22's - I'm looking to lower it. Probably going with the MCG kit over the Bell which seems to get mixed reviews. The only kit I see for 4wd is 34310 - Do I need anything extra for the Magna-ride stuff?
Anything else I should add while I'm doing it?
TIA
Got the shackles in today. Thanks man I’m gunna put them on Saturday and I’ll take some pics to show if they rub or not
What i may do is buy a flip hanger and use that shackle to bring me down to 6.5.  Iwant to lift the back half an inch
Sweet, I ordered one for my brother's 16 RCSB Sierra that we'll be lowering this month if the weather is good
I was going to do the same thing but I just can't bring myself to cut of the OE hanger off the frame - I'd rather run the short shackle and deal with the firmer ride.
Edited by Dinner
You don't cut it off. You grind thr rivets out. They are easily re installed using bolts
Sent from my SM-G955U using Tapatalk
When I have a day off work I need to scour this thread for photos of 2/4 drops. That is my next big project. Probably do wheels at the same time.
Here's a pic of my my previous truck that was on a 2/4 drop with 22" wheelsfa5ffa8d9c2c363f2d1aefbfdadee9f4.jpg
Sent from my SM-N950U using Tapatalk
Looks great! I think I'm going to stick with 20s and use summer tires, then switch back to the oem wheels for winter. Which kit did you use? I'm leaning towards belltech.
Thanks, I used mcgaughys spindles up front, and flip kit in the rear. I forget the number but it came as a package from mcgaughys.
I’m in a similar boat.
my Wheels and Tires (22s) are currently in transit. In the next couple of months I hope to order spindles for the front, and 2” lowering shackles and remove the rubber block between the leafs and the the axel. Should be about 2/3.5ish. Based on the truck above, should be exactly where I want to start. Should maintain a little rake when empty and level out when I have my bike in the back ?
will I need new, shorter bolts in the rear and what about shock extenders? Anything else I am forgetting?
Krunch
Edited by krunch
Tons of info in this thread - I've read through most of it, but didn't find the answer, so I thought I'd ask before I pull the trigger.  I have an '18 Denali with factory 22's - I'm looking to lower it. Probably going with the MCG kit over the Bell which seems to get mixed reviews. The only kit I see for 4wd is 34310 - Do I need anything extra for the Magna-ride stuff?
TIA
I too have 18 Denali crewcab with the standard bed with a 2 inch MCG spindle drop on the front and a 5 inch max track flip kit in the rear with a plate provided along with new rods for the magnaride truck rides greatIMG_0807.thumb.jpg.69d35da0d85697913da214451d0990ee.jpg9ed7dbfd90fd9980d529d630b78e90cc.jpgc0e420a85d4157859e036f1a4d17fd7b.jpg
Thanks TWill - Love the way your truck looks! Looks like I can't buy anything anyway - Nothing for sale on McGaughys site - and no one else seems to have any stock until next month... wonder what's up with that
You have to buy through this website.
https://www.suspensionsuperstore.com
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
