I don’t get why the INEZ kit gets such a bad rap on here.
I have had both MCG on a 2014 and now a INEZ kit on my 2016 and honestly not much of a big difference in ride that I can tell and my alignment on both have been put back to factory spec.
I will say though it seems like when I go over a rough road or a pothole that the rear end does shutter a tiny bit harder then I would like. But kinda used to stiffer rides for having lowered cars all my life and a lowered truck I expected the same. Just jars me a little harder then I would love lol
Youll notice balljoints going bad way more often with inez.  I pull those inez kits off for local guys all the time
Is anybody running these belltech street shocks? Looking to upgrade over the ranchos that came on it.
https://www.belltech.com/products/belltech/lowering/shocks-struts/belltech-street-performance-9688.html
I currently have the 2 inch drop shackles in the rear and like how it sits. Might remove the rear block to get it more leveled out. Was looking for opinions on these shocks.
Anything is an improvement over the Rancho's - My brother ran those when he was at a 0/3 drop and it was a big improvement
Cool thanks for the feedback. My wife owes me an anniversary present next month so I think these will be it :)
I'm running them. truck rides great, big improvement over stock even at 4/6
Do you notice difference in the way the rear rides? Smoother would you say? I already have struts in the front and notice small difference.
Thanks for the feedback. Looking forward to getting these soon.
2016 with McGaughy’s adjustable drop set at 3/5. Just had the 24s put on today. Wheels are 24x10 +25 offset on 295/35/24 tires. Noticed some fender liner rubbing in reverse, may have to mess around with it to see if I can zip tie for a quick fix.
Next on the list is to remove the side steps... was lifted before haha.
  • 3 weeks later...
Question for the bigger brains in this thread:
What I'm currently running: 2017 CCSB Silverado with stamped arms, Belltech 25004 lowering struts set to the lowest setting (the one slightly taller ring) in the front, and I have the rear brought down with a pair of McGaughys 33037 1"-2" drop shackles on the lowest setting with the block removed.
What I want: Before the Belltechs I was leveled and the plan was to bring the front end down a little to minimize the squatted look it would have depending on where it was sitting (an optical illusion from street inclines).  With the additional drop in the front, I now want to bring the back end down either to level or just a bit higher 'because aesthetics.'
Finally, the question: Assuming I'm  currently at a 2.5"-3" drop in the back, is my only option for bringing the back end down further to a 4" or 5" total drop going to be installing new hangers and replacing the stock shackles?
Flip kit and lift hanger for the rear
Finally got lowered. Referred to this thread a lot and thanks to the community for posting opinions and experience. Went with 3/5 belltech spindle & adjustable SP shocks up front, flip kit with lift hangers out back also with SP shocks. Couldn't be happier with the ride. Not overly firm but much more stable in turns. No shakes, vibes, or issues.
Does anyone have any strut spacer rings laying around that they dont need? I'm thinking about adding 1 to each side to try and get rid of the minimal running I have.
Sent from my SM-G955U using Tapatalk
  • 3 weeks later...
I have some Belltech rings you can have, just let me know where to send them.
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
