6 hours ago, TrueRider said:
I am new member to this forum and I have a question about lowering kits. I've read all the way back to page 146 and it seem like the best way to go is either Belltech or McGaugheys for a 4/6 drop kit on my 2014 Crew cab Silverado. I have the opportunity to purchase a INEZ 4/6 lower and upper A arm flip kit for a very good price and its tempting. What are the pros and cons with this kit. Should I stay away from this kit? Thanks
Inez sucks ass.  Its a copy of the djm which is also crap but its actually worse.  Youll be swapping out the upper balljoint once or twice a year minimum.
If you want a 4/6. Go with mcg.  Belltech is fine but usually at 4" in front youll need the offset bushings.   Im at 4.5 with mcg in front. And nk alignment issues
Hey guys!
Just ordered my McG spindles, 2" lowering shackles, and shock extenders (just in case) today. I am removing the block as well from the axle, but forgot to address the "Spacers" I need as the consensus here seems to be that its ok to reuse the old bolts. I know Belltech has a spacer in their kit, trying to see if I can order that separately. I think I've heard to use washers as well? What type, size, and quantity? Using washers sounds kinda hackish to me but I may have no other option. I've seen replacement bolt P/N: 15002781 referenced here as being shorter but Rock Auto's price is about $23 a piece plus shipping and it says it's not for my 2016. Any other suggestions besides flat washers I should consider?
Thanx,
Krunch
2 minutes ago, krunch said:
Hey guys!
Thanx,
Krunch
I didnt need the spacers until i pulled out the overload leaf. You should be fine without them
Much thread left on the bolts when you torqued them down? Odd that Belltech offers a "Spacer" with their kit if they are not needed.
Just trying to get all my ducks in a row for when I drop my truck off to my guy to lower it. I don't want, and can't afford delays when doing this.
Thanx,
Krunch
Thanx,
Krunch
For me it was fine.
Thanks for the info I guess I'm going to have to pass on the INEZ and get MCG
Good choice
Sent from my SM-G955U using Tapatalk
Thanx,
Krunch
For me, the biggest advantage of the spacer is it was that much less distance you had to tighten down the bolts. I didn't have access to air tools and was doing it by hand so would've taken a lot longer to tighten down the nuts, lol.
Sent from my Pixel using Tapatalk
Can you describe the spacers / know the diameter, length, and hole size by any chance?
Thanx,
Krunch
Thanx,
Krunch
All it is is a spacer. Its like a 5/8" ID hole and they are like 3/4" long
Hey guys!
Thanx,
Krunch
I did the MaxTrac 2 inch lowering shackles and the shock extenders (I did the extenders for my Magneride shocks since they seem to have more issues than many shocks). I decided not to remove the block to see how my truck would handle my 6k# travel trailer. 1 inch rake empty near level with trailer... Had to do a relearn on the Magneride shocks to get them working again properly. All is going well and to me truck rides better than it did stock.
Sent from my SM-N950U using Tapatalk
  • Thanks 1
22 hours ago, Nasty said:
Good choice
I'm getting ready to purchase a MCG kit for my 2014 Silverado but I'm not sure if the springs and spindles option is the way to go. I was looking at the strut and spindles instead of the spring but I'm not sure between the two. What rides better. Thanks 34270 kit
You want the struts as you can adjust to correct the Chevy lean
Thanks for all your help!
I got the 34270 installed last October and have zero regrets, it a really good kit.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
    • I read through that and I won't lie, my eyes rolled at some of the quirks about how it can turn off the trailer braking for example but I can see how it could help control or even up the torque applied to the ground with each wheel in a boat ramp scenario. But of course what it can't do is increase the torque to the wheels if the need is there as it ends up being like driving the four wheel drive version of a two wheel drive ( high range that is ). So far the neighbor that ended up with the 3.0 duramax with the max tow package which meant the 3.73 gears and high range only, I think its been doing ok for what he has been towing but doubt he ventures off into the soft stuff with his holiday trailer. He may have towed his dads river boat locally with it ( he always used his 6.6 duramax before ), I'll have to ask him sometime if he got into a lack of power to the wheels situation as after all that engine produces a lot of torque at low speed once the turbo winds out a bit and I think it has the 10 speed and if so they have a pretty good first gear ratio at 4.70 I see which is vastly better than the 3 or four speed overdrive models of years ago.
    • I did shorter OCI"s for many years without an issue, fights sludge and wear IMO. Recently started using Amsoil, will not do the recommended/advertised miles between changes.
    • It definitely seems quite evident that emissions and fuel economy targets rule above the best case scenario of what the engines best health and life could be otherwise. Items like DI and turbo DI engines with their LSPI issues as well as cats being reduced in life if the proper levels of certain additives were allowed to be utilized and so something has to be compromised and as you point out that is the engine protection from sludge, acid and wear which isn't in the manufactures best interest regardless to worry about in this race to profits from higher sales and so if the engines wear out sooner the next sale is closer at hand.    I am hearing that its likely the two new 2027 GM half ton truck engines will call for a 0W-30 oil, now if that is an existing oil I would have to think so but we will see in the coming months. Sadly as you've pointed out to me, over the last number of years the push has been on to reduce the actual operating temperature viscosity within each designated viscosity grade so that 11.5 to 12 range for a 30 weight for example is more in that just above 10 range at 100c along with that temporary viscosity sheer dropping it even further down as per that "energy conserving" designation, not to mention how some oils are not as sheer stable as would be ideal and that mixed with a long OCI paints a picture with a little too much glitter shall we say !.    All that and the warranty gods scaring the vehicle owner into sticking with that watery wine or risk loosing their warranty coverage if they go and use an oil that is of a higher viscosity even if it meets the emissions and LSPI requirements and would never damage the engine but may very well allow for an engines longer life depending on engine use scenarios ... high ambient temps, towing etc that push oils to their limits.
