9 minutes ago, 17gmclowlow said:
Sorry. Been busy. I returned the under bed notch and ordered the monster notch and front and rear tubs. Going much lower than I first wanted to
What size tires will you end up with and how low will you be going
Have not gotten that far. (About tire size) I'm going 6/10 for now since I have the suspension for it already. But maybe next year I'll bag it and be done. 6/10 on a static drop is very low but inconvenient for a daily driver. I am staying w my 22" or replicas. Just not sure what tires I'll run
Are you changing the front arms? Because if so id do the whole front setup not    less rubbing in the end
Yes I will be changing the control arms. Even now I have camber that can not be corrected. There are so many options available for these trucks.
There isnt many.  Im not saying the crappy djm or inez control arms. Im saying the twisted metalworkz arms or black top industries arms. They will change the upperarm mountand upper and lower arms because going that low your wheel will be pushed back into the fender. These arms. Use new mounts and tuck the front wheel in an extra inch
I was looking @ reklez. There's is similar to twisted metal works. But I'm leaning towards twisted. More people running them
Reklez are for 7" plus drop but they are bolt in requiring no modifications.  Twisted metal will work for any height and coilovers but you need to chop off the upper arm mounts and strut bucket and weld in the new
Just picked up the truck 30 minutes ago. Took it for a drive around the neighborhood and it rides good, I am experiencing some rubbing on the liner so I'm going to pull it back over the weekend.
Sent from my SM-G955U using Tapatalk
Here are some bad pictures. Its supposed to be 4/7 but I think the front is to low.ecc3c9e06373b99553cb04129af2d6fd.jpg729af56b2b5388a7551dea38345ee0b0.jpg
Thats a 4/7. Looks low because your stock tires. What kit was used
Mcgaughys 34270. It rubs like crazy, even going down the road at 20mph with the smallest dip it rubs.
How many rings did you put in the front struts? And yes you lowered the truck 4" in front withba tire thats almost 32" tall. My front tires are a hair over 28"
Edited by Nasty
I didn't do the install myself. I had a reputable shop do the work so I don't know how many rings they put.
Thats something you should know. You should know everything they did
I was going to ask those questions but when I got to the shop I forgot to ask as soon as I saw the truck because it just looked so good lol. I'm going to call them right now and ask.
    timcpeters
    timcpeters
  • Who's Online   4 Members, 0 Anonymous, 1,183 Guests (See full list)
