Thats something you should know. You should know everything they did
How many rings should be on the struts?
Sent from my SM-G955U using Tapatalk
Do you have the chevy lean? If so 2 rings in the passanger and 3 in the drivers. Assuming your kit had thr 0-3" struts
I believe I do. I'm rubbing a lot more on the driver side than passenger.
On ‎11‎/‎7‎/‎2018 at 10:36 AM, Nasty said:
 twisted metalworkz arms or black top industries arms.
 you have websites or pictures that I can see either of these. I am at a loss trying to find them. only arms I have see are the Michigan metal arms that center the wheel.
They did 2 rings on each strut. I'm going to have to go up an inch in the front, cant stand the rubbing.
Leave that alone and get smaller tires. Its gonna still rub
Michigan metalworks is the easiest but you have to have cast arms
I don't want smaller tires. From what I read there would be minimal rubbing at 4 inches up front so that's why I went with 4 but the rubbing I have is too much. I cant even get a full turn in without the tire already hitting the liner. I found a shop that's going to take care the rubbing, all I gotta do is cover alignment and bring lunch.
Im just warning you  i was at 3/6 with stock 275 55 20 and i rubbed. I went to a 265 50 20 when i went to 4/7. And i barely rubbed the carpet liner at full lock  it was perfect
Ive been through 4 dofferant heights and about 5 different size tires
I'm going up to 3/6. I may sound like a broken record but that rubbing is a no go for me. Do you happen to have a picture of the rings that go on the front struts? I may need some if I didn't get them back from the shop.
I dont have any.  I lowered it 2 years ago
For those of you at 4" up front can you guys get me some measurements it'll be greatly appreciated.
What measurements do you want?
Sent from my SM-N950U using Tapatalk
Middle of wheel to fender. I want to compare measurements between trucks
    smandy
    smandy
  • Who's Online   2 Members, 0 Anonymous, 433 Guests (See full list)
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
