4 minutes ago, krunch said:
That's kit is not adjustable to a 1/2" is it? Or based on before and after measurements this is where you landed?
Thanx,
Krunch
Front is adjustable is 1/2" increments
On 2018-11-10 at 5:09 PM, Daly said:
Just want to verify before I order, is this good for a 2/5 drop? 2018 Sierra rcsb 4x4. Keep in mind its Canadian pricing.
Sorry to keep asking, just hate spending money twice.
2210ff is too stiff, that was my set up before. try their nitro drop rear shocks
Just Bell or Mcgauheys as well?
Thanx,
Krunch
Just curious Daly. What drop, front and rear are you targeting? I also have a 4x4 and bell told me more than 2/4 is not recommended on a 4x4.
thanx,
Krunch
Thanx,
Krunch
Not sure about Mcgauheys.
thanx,
Krunch
All drop kit companies are gonna say that because of the cv axles. When I had my 14 dropped 4/6 I had the DJM arms that were 4 inch and they said they wouldn’t work but couldn’t give me a reason why. All they told me was the don’t recommend more than 2 inches in the front on a 4x4. I ordered the 4 inch any way and never had any issues with cv’s or operating in 4wd. I think it’s to protect them.
Thanx,
Krunch
Anything with a lowering strut
Shouldn't the McGaugheys (#34270) 3-5 / 4-7 Deluxe lowering kit with shocks and struts be capable of only a 2" drop in the front? Since the spindle is 2" and the front struts are adjustable from 0"-3"? I'd like to try and go ~2.5" driver and ~3" passenger in the front, to get rid of the lean and try to fit the 275/55R20's with minimal rubbing.
Yes
thanx,
Krunch
2/5 is the target for now.
  • Thanks 1
204-WPG, I should take a rip to Winnipeg and check out your truck and chat if I could ever find the time. You don't happen to visit Brandon from time to time by chance do you?
Krunch
As I just purchased them for my 2/5 drop that is more like a 3/6 drop.  Nitro 2 shocks are better?  I'm bottoming out on the smallest of bumps and its just irritating me.  Especially since I can't get any help from the shop that did my drop and the damn truck is brand new.  I guess I'll contact Belltech tomorrow and see if they can exchange the 2210FF that I just bought.
What are your front and rear measurments
Idk the measurements exactly. I had the dealership measure for me.....mine vs. stock and thats what they came out with. 3/6 lower than the stock height.
Post a picture
Sent from my SM-G955U using Tapatalk
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
