315/50/17 in the rear and 235/65/17 front. Yea 4/6. Just looked up Twised Metal and I think I will order that front kit for sure. Didn’t see a rear kit other than the 4 Link. That Silverado is bad!!!
Look under "shocks" its the kit with included shocks.  I have it. Just waiting for my welder to have time
Nasty, thanks for directing me to Twisted Metal Workz!
Looks like some awesome kits there!
So with the dual adj shocks you'll need to weld the relocation mounts?
And what is the coilover in the background? I thought that might be a model of the setup, but it looks like a coilover.
On the coilover page, is the Universal kit for 4x4?
And is this their only front kit?
I know it is included with the 4 link kit, but that's the rear suspension...so same for front and rear?
It doesn't mention much about the type of control arms needed...I think I have stamped, in their pics it looks like steel (after market).
I guess I should give these guys a call when I'm ready, but I'll need to think about this first, since there is welding involved.
Does not look like reversing back to stock would be an option...just in case I decide to sell down the road.
Also need to search out a good welder...more $$$
The shock relocation comes with the 4 link if you order the 4 link. But theres an option for just the shock relocation
Got a quote from Four Wheel Parts in TX today to purchase and install Supersprings SSA28 ($300) and Belltech ($65) 2 inch lowering shackles for a total price and 3 yr warranty of $890 including 8.25% sales tax. Does this sound unrealistic in cost? He said they planned for 3 to 3.5 hours of work. They also have already verified with Super springs and Belltech that neither will have any issues with the other product or issues working with my Magneride.
I would love to do it my self just don't have tools or time to devote to perform the job properly. If someone lives around the Plano, TX (DFW) area and you have a different place you recommend please let me know. Thanks.
Sent from my SM-N950U using Tapatalk
Lowering struts are 80 bucks a peice.  You can save money doing struts in front
4 minutes ago, GMC_SD_Ult_16 said:
Just lowering the rears 2 inchs. Does that still apply
Rear no.  Im just talking about the front.  Rear os shackles no matter what. But 300 bucks for springs is ridiculous
You can get 3.25" of drop in the back with just shackles and removing the block. Do you even need the springs.
Front springs. Not leafs
Ah, I read springs and immediately think rear leafs. Always referred to the fronts as coils. (Unless old leaf spring 4x4's)
The item I am referring to is SuperSprings not just springs. The drop shackle kit is the Belltech 6401 and I am considering removing the block as well.
The SuperSprings basically are an add on leaf that only engages when you add weight to the rear. See the below link. They are designed to help you drop very little, if any, in the rear if hauling a trailer etc. I have 6k trailer that when I drop the back I don't want to go negative on my front being higher than the rear. I do have a wdh but I don't want any sag and this further helps sway. My question is for 3 to 3.5 hours of work is $525 reasonable on this type of project.
SSA28 | SuperSprings for Ford F-150, Chevrolet|GMC Silverado|Sierra 1500, Nissan NV 1500|2500|3500 https://www.amazon.com/dp/B00715DL8U/ref=cm_sw_r_em_apa_i_4-wjCb0DJPB9G
That sounds like they are overcharging you.  Its really up to you though.  They'll probably want to keep the truck overnight but in reality thats a half day job in the garage or driveway.  For them its probably a 2-3 hour job.  I would check out instagram and facebook for truck groups near you and get suggestions on other shops nearby.  Also that 3 year warranty is just a joke.  What are they putting a warranty on, the bolts not backing out or nuts not coming off?
More confused now! I want to drop my 2018 4WD RCSB Z71 Silverado 3" in the front. Just when I thought I had my answer with the combination of Belltech 2514   2" drop spindles combined with Belltech 25004 struts set at 1" drop, I come across the Belltech 15002 coilovers which it indicates are not only compatible with 4WD's (as there webpage does not with the spindle/strut combo) but are adjustable from a 1 to 3" drop? Why wouldn't I just go with the coilovers and set to 3" drop?  Will these move the wheel off center more than the other option???? There must be an advantage to the spindle /strut for 3" front drop? Or is there? If you went with what Belltech's webpage suggests for what I want it looks to me like the coilover is their recommendation?
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,211 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
