4 minutes ago, Nasty said:
Looks like 2/5 to me
Thanks Nasty, So I should be good to run the OEM Denali 22's with this drop? I can't figure out why its bottoming out so much if its truly a 5" drop in back
Edited by BranMo103
forgot to add something
I need measurments to make sure.
What measurements do you need?  Top of tire to wheel well?  Center of wheel to wheel well?
1 hour ago, BranMo103 said:
As I just purchased them for my 2/5 drop that is more like a 3/6 drop.  Nitro 2 shocks are better?  I'm bottoming out on the smallest of bumps and its just irritating me.  Especially since I can't get any help from the shop that did my drop and the damn truck is brand new.  I guess I'll contact Belltech tomorrow and see if they can exchange the 2210FF that I just bought.
Had the 2210FF installed with the 3.5F 6R on my regular cab standard box and I love them. Rides great.  Everybody's truck is different, regular cabs are different animals. Had the Nitro shocks in my 2002 with a 2-4 and was never happy with them.
Center of hub to fender lip.  Front and rear
Front is roughly 18". Rear is roughly 19 3/8".  But I've had a couple beers so my hand may have been a little shaky. :D
From my measurements youre about 3.5/5
I ordered new struts and shocks from Belltech.  The shop I went to used MaxTrac kits for both.  Honestly I'd like to be a true 2/5 but given what I've got, I'm trying to make it work with having a stiffer ride and being able to run a 22" wheel.  I wanted 24's but that's just not practical for what I do with my truck at this time.
Plus the a**hole that owns the shop I went to doesn't seem to really want to help me get the right ride for my needs.  I almost wish I never went to Reklez.
Reklez is usually really good. If you wanted 2in front then all you needed was spindles. but a 2/5 on a crew cab will have tmsome rear lean
I called them up and after a month of leaving voicemails, I finally got in contact with him. Told him what I had going on and that I didn't really want to be that low, as it seemed lower than what I asked for.....dude straight up told me, "that truck is not that low" :cool: I'm like dude Ive driven trucks everyday for the past 13 years, the truck is lower than a 2/5 drop.
And thats why I really went to him. I was going to let him re-bag my '66 Caddy but after this.....uh, nah.....I'll pass.  Not interested.
    contrabombarde
    contrabombarde
  • Who's Online   5 Members, 0 Anonymous, 1,158 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
