I hope this uploads correctly. I plasti-dipped my bow ties and used the bright aluminum metalizer. You have to spray it over a plasti-dip base and I did that over a white basecoat. I think it matches pretty well. I am a terrible painter but this stuff makes it easy!
That looks awesome. Do you have to remove the bow tie to paint it or just tape it up good and spray? I was going to order just the normal black but this looks really nice.
Thank you! essentially you paint the whole bow tie and some of the car and peel off what you don't want. The gold part of the bow tie has a line between the chrome so it creates a clean peel so just the gold is covered. It's real slick- I painted an old license plate first to build a little trust in the product and me of course.
Got this pic on the parking deck the morning after a rain storm here in NC.
You buy your truck at Hendrick in Cary?
I've had mine since May. LOVE IT!
Great pics guys! Some real inspiration for what I want to do to it!
IMG 20150922 190752326
I looked thru here and didn't see anyone who's changed out their taillights. Has anyone done this? Seems like smoke or clear lenes would go good with silver.
I have Recon smoked LED's. I do not have a pic from the rear though.
We take a pic of your rear and post it up here so we can see it. Haha.
New to the forum, lots of nice trucks fellas. Here's my silver ice 2015 post-150290-0-57268900-1447211046_thumb.jpg
Edited by silver15
Made some changes to mine recently. Trimmed up the front valance, added tow mirrors, and a rearview camera backup kit. Next on my agenda is to plasti dip my front bow tie. Rear one was removed long ago.
  • Like 4
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
