Nice looking truck!  That grille looks different than mine?  Are the headlights upgraded too?
His looks like it’s an LTZ Z71. Those factory headlights that are standard on LTZ/HC models 2016+ and then just a typical painted Ltz grille it appears. What package is your truck? That’s probably where the difference is
CKrado - I have a 2018 LT Z71, so makes sense since that one is the LTZ edition.  I see your truck in your profile, I like those tire/rims.  What size tires do you have on your truck?  Mine are just the stock 18" with I think 31" tires.
I have the BFG K02 305/55/R20 and love them. I believe the rims are 0 offset
Grille and headlights are stock. '16 Z71 LTZ.  tires are Nitto Ridge Grapplers 305/55/20 on 20" american outlaw wheels. 2" front level kit.
I happened upon this thread while looking up info for paint codes for my Silverado. Nice to see some fans of Silver Silverado's and Sierra's. :) I added a picture of mine below. I have been looking at buying a set of fender flares. I'm not a pro with it comes to painting and I have not ever done any paint work on a vehicle. But, buying a set of fender flares that are painted is a pretty nice chunk of coin, so I have been looking into buying a set and just painting them myself.
Do any of you have experience with this and might have any advice?
Look's Good - What Brush guard is that ?? Thanks
Thank you. It's a Westin Sportsman X.
