What ball mount to buy?
Imcrazy
Looking to get a good hitch ball mount for my truck. '14 sierra 4.3L 4x4
My buddy told me I should use a 5" drop to get me around 12" of height from the groud.
I'm guessing a 2" ball will meet most of my needs?
Looking to tow the occasional u-haul trailer nothing major or frequent, my truck does have the factory receiver and wiring.
Thanks,
Aaron.
5 seems like a lot! I normally run a 2in drop " I also have a buyers adj triball on the way since I can get it at employees prices"
Sent from my SCH-I535 using Tapatalk
I run a 2" on my 2004. We run a 5" on our lifted ram 2500.
Yeah 5inch is wayyyy to much for a stock height halfton. I don't know if u haul trailers have different size balls but I have a smaller trailer that uses a 1 7/8th ball, might not be a bad to get both
Just get one of those straight shaft tri-ball Reese hitches. Work perfect for stock height half tons and you have every size.\
I personally have a 10" drop tri ball B&W hitch. But Im lifted 8" (suspension) so its necessary
Oh yea for ball size 2in is pretty standard u less your pulling a log spliter (1 7/8 ) or a car trailer (2 5/8 )
Thanks I knew that
Picked up a 2" with a 2" drop tonight at wally mall for $20.00 now I need to find something to tow lol.
Get a level & measuring tape. Only you can tell us what drop you need with your truck.
Because it's unique from all other 2014 sierra 1500's? I've got 17" to the center of the hitch receiver
This all depends on the trailer being used. I use a 3inch for my car hualer and 2"ball and a 2inch drop with a 2 5/16 ball for my 18 ft enclosed. Reason being is my trailers are different heights as my enclosed sits lower to the ground and but has more tounge weight squating my truck more. The key is a lever trailer. A nosed down trailer will get squirly and sway when braking and have excessive tounge weight; a nose up will sway like crazy on the high way also screwing up your weight distribution up as well as ruin your trailer tires. I run weight distrution hitches that are adjustable so I can adjust to my load. A 2 inch drop is a good start for the trucks and 5 inch on the tahoe suburbans due to receiver location in the bumper instead of under like the trucks. BTW all uhual trailers are 2". My open trailer weighs 2200 empty and the other is 3800 empty
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
