Anybody that will price match. I got mine from Morrie at tonneaufactoryoutlet.com
AutoAnything.com is running a $224 rebate right now. They also offered to match the deal that AMP is running to through in a free bed step. That deal is good for another week on the bed step.
Do you have a picture of yours? I'm really wanting the power steps but, I've heard good things and I've heard bad things about them. I've never actually seen them in person. The only ones I've ever seen, were on a Tahoe, and were factory.
Edited by strickster1
Looks good! Same color as my truck. Are they aluminum or steel?
16 gauge zinc coated steel, has like a bed lining texture to it too
SHIT! I knew this was going to happen. Purchased mine last month and only got a $100 rebate
I know how you feel. I bought my AMPS on 3/24. I could really use the bed step. It would be the perfect combo with my Fold-A-Cover with that front panel. Doh!!
I'm not trying to step into the middle of this fight, just FYI:
I have had Amp steps on 2 trucks through about 7 northeast winters total with absolutely ZERO problems with them freezing up. And the Amp warranty is 5 years not 1 ...
Proves the rest of the whiners don't have a clue what they are talking about thank you! HAHAHA!
Hi guys
Anyone have experience with ICI Magnum RT step bars on their truck? Looking a buying a set but have not seen any reviews anywhere for them. Let me hear if you have and pics would be great.
Thanks in advance
I misunderstood the offer. The rebate for $224 is the offer to throw in the bed step. You don't get both the $224 and a bed step. Hope that clears things up a bit!
What did you pay for your steps? I am seeing them as low as $1199 (no tax, no shipping and without the plug an play... which I want to add).
Apologies in advance if this is somewhere in these 69 pages...
But, I am having some trouble finding installation instructions for steps on a double cab. The steps are from Iron Cross, so of course the dealership wont touch it. And, Iron Cross's instructions only go up to 2011 Chevy's. Ideas?
I have a 2016 Crew Cab short bed Z71. I'm trying to decide if I want wheel to wheel 4 step NFAB steps or the standard cab length 4 step. Anyone with these have any pros/cons to this set up?
Here is the ad and pictures. Dropped price to $350 after doing some research. This is the pair for half the price of one bar if you order from GM directly.
http://www.gm-trucks.com/forums/topic/186839-2014-6-chrome-nerf-bars-for-gm-1500-crew-cab-350/
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
