My only complaint is with the "Go Rhino" logo that is riveted on the side of the right running board. The logo on my right running board is riveted upside down. I need to contact Go Rhino to see what they will do to make it right. Either money back or a replacement board would work for me. Here is a picture showing the upside down logo:
Instead of going through the hassle, I would just drill out the rivets and replace with small bolts and nuts with some lock washers.
Thanks tahoe08!
For the most part, install was pretty straight forward. The only tricky part was getting the running boards to line up perfectly straight, so that the gaps were the same in the front and the back. A little tweaking with the brackets and bolts did the trick. I would say they sit fairy tight to the rocker panels (between 1/4" to 1/2" gap). They can be adjusted to make the gap even tighter. Here is a close up picture:
I purchased mine a few weeks ago from:
http://www.autoanything.com/nerf-bars/go-rhino-rb10-running-boards
They were listed at $495, but I had a 22% off coupon code that I received via email. Also, I went through Chase Bank's online shopping portal called "Shop Through Chase" to get an additional 4% cash back (chase rewards card is required). After all discounts, my final price ended up being $370.66 shipped to my door. They did get back ordered for a couple weeks so I had to wait longer than originally expected.
Here is a 20% off coupon code if you decide to buy from them: BASIC150 (expires 8/21)
I've only had them on for a couple days so far but I would definitely recommend them.
thank you - looks good
Thanks tahoe08!
That's for when the truck gets rolled you can still read one of their logos.
Sent from the future via a wifi time portal.
Thanks tahoe08!
Ask Rhino for a new logo , and drill old one out ? or leave it off (like someone else said).
Thanks tahoe08!
Alex - Your post finally pushed me over the edge to buy them. The 20% off coupon worked too! I've been trolling various sites trying to find a price drop on these exact RB-10 and low and behold it was right here in front of me! FYI, I will post back if my logos are upside down.
First off I want to say that I love the look of my GoRhino RB10's!
The sad part. I will be installing my 3rd set of RB10's in less then a year. I have had 2 sets that the coating has started to peel off of. I called GoRhino and they wont deal directly with you so I have to go through the shop I bought them from. Luckily the shop is amazing and has fixed me up with no issue.
It always starts to peel at the slots. It wont flake off but it completely lifts from the surface in a large area.
GoRhino told me they were experiencing "Adhesion Issues" and it had been fixed. Unfortunately it was not fixed on my last set of boards and th coating has peeled off again..
Hopefully You guys have better luck then I do.
before I buy, How long did you have the broads . we used a lot of road salt in the winter time , are they going to hold up ????
Thanks tahoe08!
ANY problem with the coating pealing off ????
Installed in September, changed in April. I thought it could have been the salt aswell. However I've had a repeat problem since April. I would think that the salt/ice magnified the problem as in once it started to lift and all that salt/water got in and freeze/thaw cycle probably escalated the problem.
That's a bummer, what's the warranty on those? Have you thought of stripping that coating and getting them line x'd for a couple hundo?
One year warranty. I have thought of that but thats just ridiculous. The closest Linex place is 14 hours away and I paid money for these! I think they should hold up for longer than a few months!
I just got off the phone with go rhino - they had a problem with the with line-x sticking to the power coat broads. But they will cover it . HOW many others have this problem . Lets hear from you guys .
Edited by tahoe08
Thanks tahoe08!
Just drill out and remove. I need to put a black bolt in place but honestly doesn't look bad with just 2 tiny holes. I thought the badging was ugly in the first place.
Had mine only a month but no issues. Well see though, kinda has me worried now.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 162 Guests (See full list)
