I've seen videos of people adding a charger to their "older" truck. I'm going to do it on my 2014 (got it 2 days ago).
Sent from my XT1254 using Tapatalk
Ive seen the threads on here of people doing aftermarket adapts. Just curious if anyones gotten the OEM side of it done.
By oem i mean GM parts. As i mentioned from say a 2016 model
Edited by Liquidfx17
the only way to get the wireless charger in the 2016 is with the full console , its not avaliable with the jump seat console ..... that being said does anyone know if the two console lids are interchangable ? ..... can you put the full console lid on the jump seat console ?
No, the center console lid is narrower
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
I really want to do this to my truck. Does anyone in the chicagoland area, or close to it have any experience doing this? I don't trust me self with such a big install. lol
i have the full console in my 2015. So im curious if i could just purchase the arm rest itself and swap it.
I don't see why it wouldn't work ....
Edited by Rayce08
I ordered all the parts to do the console swap from Gmpartsheadquarters.com . Hoping all goes smooth. This is the first time I ordered from them as they were a bit cheaper than gmparts direct. I placed the order yesterday paying with paypal and besides the normal paypal receipt email, I did not get anything from them with an order confirmation although the page says I should of received one within 5 mins. Of course they do not have a phone number listed, just a contact me page to send a message.
Question to people who ordered parts from them, did you receive an email from them right after you ordered? Did you receive tracking info?
I ordered my parts from them and received everything in mint condition. I did receive a confirmation email not sure about tracking info. Others too have ordered their parts of that website, you should be fine.
ok did you receive the confirmation right away? Did you use paypal? Just want to make sure they got the order, I am short 560 dollars on paypal so they have my money at least.
I received a confirmation the next day.They emailed me every day to let me know where my parts were until I received everything since my stuff came from five different locations.I wouldn't hesitate to contact them if you have any questions,they were very good to work with.
Edited by 1911-A1
Today was a holiday. The dealership may have been open for sales and not the parts or service dept? Just a thought.
remove the lower glove box and you will see the HMI module....you will see a usb port ......plug your usb there . not behind the radio
for the console and manual transfert case ......... :)
no interference with arm and console in every position (4x4 low to 4x4 hi)
still miss the side cover ....i will post a pic when complete
hébergeur images
ravageur1972,
I also have the manual transfer case. Any pointers/observations that you can make? Is there a boot below the floor shifter that keeps road debris and water from coming up? Did you modify the lever at all?
Sent from my STV100-1 using Tapatalk
    • https://www.msn.com/en-us/autos/general/what-makes-this-1963-ford-falcon-red-rocket-special/vi-AA2asoRz?ocid=winp2fptaskbarhover&cvid=be9c1b4f79ff4211c526abd60f6da012&ei=16
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
