AgDocktor: looks like there are two screws on top also.Check this thread it might help or the OP might be able to answer your question
3 coil wireless charger install in 2015 Sierra Denali
Edited by 1911-A1
Thanks for that! I really appreciate the link. I will keep you guys posted on my progress.
Sent from my SM-N910V using Tapatalk
Hey guy just got my console in and wanted to say thanks for all the help from the forum. Getting the jump seat out was much harder than I thought but getting the new console put in was much easier than expected. I only used two bolts where the bracket mounts to the dash so that I didnt have to take any of the dash apart and the console is in there solid. I love how much storage room this thing has.
IMG 20160107 153920
IMG 20160107 154055
Nice, I bought all my console parts, just waiting for free time to do the install. Did you get the front three USB'c to charge?
Hey guys I just got my console in, started on it this morning at 9 and I'm wrapping it up at 1:30. Also I have the front 3 USB playing music and charging and I have all 4 cig outlets working and the interior led for the console is wired to my cab lights. Everything went smoothe and I want to thank everyone for the info and insight on the process. I absolutely love this thing. 108199a698f66c4b54c195c18b41d04e.jpg8420513fc28eaa0c4b9cd983d49f2585.jpg0d3bbf23485c65d7b14d688a4bfce04a.jpg
iPhone 6 '14 Silverado
That's awesome Keith!! How did you tap into the lights to get the LED to work? Is that the blue wires in the picture, underneath the console? Also as far as the charging USB's up front: did you use the AC Delco USB male to male connection; one side into the back of the chargers and the other into the HMI?
Hi Guys. I've read till my eyes are crossed so I'll just see if you guys can help. I'm thinking about buying a 2014 GMC Sierra 1500 All Terrain. Currently, it has a fixed center console. However, I have a bunch of kids so I need the flip up console. If I buy this truck, will I be able to buy a jump seat to put it its place? Will it bolt up easily and wire easily? Looks like most people are getting rid of the jump seat in favor of the center console.
Also, anybody on here happen to have a black leather one they need to get rid of?
Thanks so much for any help. Need to buy pretty soon.
For the led light, I took the pigtail and unplugged it from the led. Then I followed the wire down about 4 inches and cut it and taped off the dead ends. From there I took the plug with now bare ends and spliced them and butt connected it to the 2 blue wire you see. One marked negative the other is white it's the positive.
As far as getting everything up front to work I removed the entire jump seat harness from the jump seat. I then plugged the harness back into the floor plugs under the passenger seat. I used all of the connections up front and that's all.
Yes, they should be interchangeable. Where are you located? I have a black leather center jump seat that I will be removing soon and selling.
The pigtail of the console LED?
Edited by nolabell
I'm in SWVA. Close to the VA TN line. Wonder if the color would be the same. Looks jet black to me (leather). Not 100% sure this will be happening, but it might.
I think they are the same, black leather with white stitching. We are pretty far, I am New Orleans, 8-9 hour drive away
Edited by nolabell
Yes the console led I left about 4 or 5 inches of wire on it then plugged it back into the led
Hey what part of Nola you in? I'm in marrero
Wow, I actually work in Algiers and live in Metairie. Small world, might have to summon you for some help with the install lol. Do you have a 2014 or 2015?
    • 2026 3500HD.  Mostly empty. Grocery getter. What tire pressure are you running for 37x12.50x20. I have 37x12.50R20 Toyo Open  Country RT pro and been running around 55 lbs front and rear and it's too much. Tires are wearing more in the middle. Toyo says 45 front and 50 rear. Chalk test and it's still too much. I lowered it to 40 front 44 rear see what happens.
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
