Yes everything you already have in your jump seat will work in the console if you re-use the harness. The rear 12v plug will have to be spliced into the harness as the jump seat does not have one. It is really easy to do, If you leave the console harness attached, track down the + and - that lead to the rear 12v and splice them to one of the existing wires for the 12v inside the console.
Thanks, but I have a crew cab and my jumpseat has the 12V outlet in the rear so I'm guessing I'm good to go.
I guess i forgot it was there lol. I think I did it as it was easier to do rather than take apart the rear panel or maybe the wiring was not long enough.
Ya, I was pretty pleased, even found a place for my DQ-61's controller (that's what the knob and LED's are under the 12-volt outlets are). My biggest concern was to have to redesign a sub-box if it was too long but that turned out just perfect as it allows just enough space for full sub cone excursion. May still redo the box as this one was supposed to be just a temp one and do a bit of conturing of the box edges, then get it wrapped in matching vinyl to give it a factory look. May even move the sound processor into the large bin with a false floor over top of it to protect it since it is so huge. I may just wait on that mod as AudioControl's new DM-608 processor should be out soon.
Edited by Deanjo
Hi, Deanjo. I need that exact same center console. Would you mind telling me where you bought it? Part numbers? I've been looking everywhere and can't find them. If you could please respond, that would be great! Thanks in advance! - JorgeGomez4462
Part Number 23468002, This part number looks like it works on the Silverado, Suburban, & Tahoe. Has anyone had any experience with this? I believe the 2015 consoles fit in the 2014 Silverado's as well but I haven't seen anyone else using this part number. I have read that the Yukon consoles do not fit so I want to make sure this will work before purchasing on CL.
http://www.factoryoemparts.com/2015-16-gm-silverado-suburban-tahoe-center-console-assy-black-23468002-23491330-23468002
Edited by TPuiia7
That part number WILL NOT work for the Silverado or Sierras. This is for Tahoes, Suburbans, and Yukons. The front of the console is much different and would not fit in the trucks.
Thanks Druit. Most of posts within this thread and a couple others pointed to no. I have seen multiple sellers say it is compatible with the 2015 Silverado, like the link I posted.
Does it just not fit correctly against the dash?
I am doing opposite of this and removing the console and adding a jump seat. I started looking into it and it appears to be no carpet under the console. It is cut just past where the console will cover. Anyone that has added a jump seat run into this? It appears I will have to add a carpet kit to get this done right now.
I'm more than willing to sell it but i just need to find the carpet first. Does anyone happen to know of a place to get it I would prefer oem. If someone knows a part # that would be great.
Ok. If you don't have a Jumpseat yet, I would have one if you would sell me your Center Console if your interested. I have the leather one. Maybe if you don't want/can't find the carpet, you could buy the Weathertech floor mat that goes through the middle.
In line if your sale falls through, very interested!!! I'll look to see if I can find where to get carpet.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,254 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
