Perfect.
Thanks
Yes, sir. All good. Give it a shot. You may need a certain angled socket wrench to get the bolts off, while the main seats are in place, but just tinker with it, they will come off.
This is a pretty long thread and I've looked through most of it but I have a 2016 with the full console. Say I just wanted to remove it to install some electronics under it. Is there a step by step for taking it out?
  • 3 weeks later...
I am not comfortable trying this swap myself. I have contacted every Chevy dealer within 100 miles and none will do it. If any of you that have done this successfully are interested in making some extra $$, I would happy as hell to pay you to do it for me.I live in Dayton Ohio I can drive to you around 250 miles. I hate this friggen jump seat so much I am ready to buy a new truck if I cant get this done.
I am still looking for someone to do this,I came milliseconds away from buying a 16 a couple of days ago, I still have salesmen calling me all day. Again if ANYONE wants to make some $$. I will come to you with the parts and Cash and beer.
Where you located?
I'm still a little confused with getting power to the front usb's to charge. I know how and where to run the extra USB cable but how are you guys connecting the power to the USB socket. I know there is that expensive connector but whats my other option to connect to those pins??
I removed the harness from the jump seat and used it for the front of the console it has the plug you are talking about.The usb's in the jump seat use the same plug.Others have found different solutions but this worked good for me.
I have a console I am looking to sale, figured I would put it here before eBay. All parts including harness. It's heavy so shipping will probably be a lot so I am willing meet someone if close enough. The back dust cover for the 12v plug has been broke off but other than that it's like new. Came off a 2015 2500HD LTZ.
As far as price make me a offer.
How much. Will it fit in 1500?
Yes it will fit in a 1500, correct me if I am wrong but they are all the same. As for how much I would say $400 would be fair but make an offer. I checked shipping to you and it is not cheap with the size/weight, that is the only downside..
How heavy is it? And can you send more pic epically the break you wrote of
The console itself is just over 32lbs. My zip is 91730.
I added pictures of the damaged area and of the console.
I removed it from the truck with about 10,000 miles and sadly that little cover broke while it was being stored.
Very interested. Could we come to terms on shipping and price as a package thing. It says ~$140 to ship to where I am at in Indiana.
Can you help me out as well man. I cant locate some of this stuff. Much appreciated
Hi, Simonmcnasty, I can get that all done for you. I'll message you.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
